Trillwizzard
- Jan 4, 2017
- 12
- 6
- 2003
- Hemi 5.7
Can't wait to fire it up so far I'm up in the air on that I think I may swap the pcm over to the 05 before having it tuned? Not driving to much until I get an a/f wideband in? Your thoughts on that ?
As for the torque converter it's still stock was thinking maybe a 2800-3000 stall I'm really not very automatic trans savvy I grew up driving sticks but I can replace a converter and would not be hesitant to do a valve body kit
Will it run worth the 03 pcm occasional stalling, low vacuum etc.. but run and for the pcm swap I just need an 05 pcm for a 2500 5.7 auto correct and the tcm I remove?
I would suggest hitting up Jay Greene for the 03 pcm tuning, he has tuned a friend's 03 pcm with a pretty radical cam. Jay Greene is on FB. I wouldn't be too concerned driving it without an a/f wideband if you are just putt-ing around. I would not go wide open throttle though. I did run the Edge 11" 3000 stall with my 268 for a long while. Ran great. Just upgraded last year to the 3800. I gained quite a bit by just swapping out the converter and getting a refresh on my custom tune from Hemifever.
Why didn't the pacesetters fit?
