For the past month I have had an issue when I turn the heat on it will blow hot out of the passenger side vents but the drivers side vents are cold. I am not sure what is causing this. Vaccum hose maybe? Thanks in advance
Start by flushing your heater core very good. That should work, unless core is just shot.For the past month I have had an issue when I turn the heat on it will blow hot out of the passenger side vents but the drivers side vents are cold. I am not sure what is causing this. Vaccum hose maybe? Thanks in advance
Jamman, have you flushed your core? I thought it was mode doors, but was just clogged core. Same exact symptoms, heat on passenger side only.Ugh you are probably in for a big fix, sorry. Sounds like the mode 1 or mode 2 doors, I forget which one has the 2 flaps on it but I have the same problem on mine, did plenty of research and decided because of the complexity of the various fix scenarios I'm avoiding it LOL.
Heater treater site explains what these doors do and the fixes, here is one of their more informative videos:
https://www.youtube.com/watch?v=4uNbQd816G4
