Liquid_Squelch
- Dec 27, 2011
- 3
- 0
- 2011
- Hemi 5.7L
I'm looking to add an alarm to my 2011 Big Horn that uses a RKE in the ignition instead of a regular key. (I think it is called the RKE) I would like to use the OEM keyfob to arm/disarm the alarm instead of having to put another module on the keyring - and most importantly - in my pockets!
I'm looking at Viper systems for now, but I am open to anything that will allow me to use the RAM RKE. (I personally hate the multi tone siren that viper has been using for years) I understand to use a viper, i will need the XpressKit and have it programmed for a 2011 RAM.
However, I need to have the perimeter sensor on it. I had a few 'youts' steal the valve stem covers on my truck. Fool me once...shame on me. I am also up in the air on a glass break sensor since I park on the street.
With that said, is there an alarm system that I can use?
And, are alarms still crazy insane to install, or does everything now interface into the Xpress Bus? If there is 1,000 wires and relays to tap into, I might as well let an authorized dealer install. But, if I can just hook up 12v and ground into the Xpress bus, i'll take the challenge myself.
Finally, if I am using the Xpress Bus with an alarm, do I lose the ability to have remote start from the Xpress Module?
Thanks for the help.
