AmoAgave
2014 with the 5.0 Uconnect.
Adding my amps, Alpine DSP etc. Picked up the Audiocontrol LC2i as a LOC.
And here's the problems.
Running the front speakers to the LC2i (I'm sure the LC6i is the same if anyone has input). Wired in 150 Ohm 1/2 watt resisters as I've read on this forum, the audio forums and an email from Audiocontrol. There is power running through the speaker lines since it turns on the Audiocontrol unit (which then turns on my amps and DSP). Works like a charm, except no music. NADA, Zilch.
I hooked up the amps to my phone and they're not the problem. Work fine.
Pulled the DSP out of it just to simplify troubleshooting.
Tried it without the resistors just for kicks. Nothing (though hooking it up gives my some static for a second). Hooked up two resistors just to see. Nothing.
I then hooked up one of the 3.5's from the dash directly the speaker wires and also have no noise on those (just tried one channel).
I attemped to wire the 3.5 in parallel to the LOC (with no resistor and with resistor) and still nothing.
I'm desperate at this point. Started this last weekend, had to work all week and assumed I would find the problem this AM. But I can't find the problem. lol.
