Help
My cluster doesn't work. When I start the truck I just get a red dot and then nothing else. Everything else in the truck works just fine
I've had mine take a few seconds to start working twice now. I believe it just didn't boot up correctly when the truck powered up.
Cycling the ignition fixed the problem both times.
Course my cluster is from a different truck. Is yours the one that came with your truck?
Check f49 and f88 and go from there f49 is a red10 fuse and f88 is a blue 15 fuse
I would guess it has something to do with f88 then
Thanks man. The f88 fuse was blown.
