Key Fob Signal BOOST!
bashby80
Mountain Home, ID (not by choice)
Does anyone know of a way (or if possible) to boost the signal strenght on the OEM key fobs? It seems that my lock/unlock doesn't work as far as I think it should. I haven't measured it, but the remost start (DBALL) would work better if I could start it further away.
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
This might sound stupid but put the FOB under your chin with it pointing upright... It will give you more range..
I had 14 people outside the office last week doing this because they thought I was lying.. I made them believers :D
For some reason it really works
Firehawk
Rogers, Ark.
2011 RCSB Express
5.7 Liter Hemi
Agreed completely, I locked my Ram from about 15 houses away before and I was amazed how much difference it really made.
the codes
Houston, Tx
Magnum 5.2
x2!! been my trick forever lol
Tapatalk Addict
rennaissanceman
Tampa, FL
I've heard that helps, something to do with the shape of your skull makes it act like a satellite dish. Mine gets terrible range as well, and it's distance isn't consistent either, it fluctuates between ****** and ****tier
TheMaddog
DFW
I locked my moms car from like 3 blocks away. Put it right beside my bottom retainer(metal) and it locked. I knew it was mine because I made that ***** honk 9 times
the codes
Houston, Tx
Magnum 5.2
get a viper alarm lol mine has a mile range LOL and its no bs, I tested it lol
BigDogg795
Ronkonkoma, NY
Soooo...basically I'm blasting a radio signal into my cranium? Jeez, and I thought it was just cell phones I had to worry about! :drool:
:naughty:
EvanYJ350
2016 2500 CC Air Susp
6.4L 392 c.i.
If I remember right, the owners manual says the remote start signal has a farther range than the power lock signal ???
EvanYJ350
6.4L 392 c.i.
The RKE system allows you to lock or unlock the doors
and activate the Panic Alarm from distances up to
approximately 66 ft
REMOTE STARTING SYSTEM — IF EQUIPPED
This system uses the Remote Keyless Entry
(RKE) transmitter to start the engine conveniently
from outside the vehicle while still
maintaining security. The system has a range of
approximately 300 ft (91 m).
bashby80
bashby80
Well, I guess I'll give that a try when no one is looking. Ha-Ha! My truck didn't come with the remote start stock, it is the DB-All system that you have to press the lock button 3 times to activate the sucker. Thanks for the tip!
quietpeen
2021 TRX
Hellcat
damn, i don't know if i believe this chin thing....LOL
bashby80
bashby80
I didn't feel like walking down my block, but I tried my key fob out of range with it under my chin (looking ridiculous) and it WORKED! It's weird, so I'll do it when no one is looking or faking a chin scratch. haha. Thanks again, guys.
