WadXpress
- Nov 29, 2014
- 1,162
- 397
- 2014
- HEMI
So 3 weeks without a stereo so far and it sucks. I'm working swing shift away from home so I'll be home iN 3 weeks for 2 days so I wanna have the problem solved and have a new Hu on the way by then if I need one.
So I took over Etrozes q&a thread for a week and it's suggested I start my own.
Factory my truck had a Ra2 5.0. I did the 8.4ra4 and Kicker upgrades awhile back and wanted more since my previous vehicles all had systems.
Decided on jbl ms a5001 and jbl ms a1004 amps, focal ps165 components, a Sundown SA12 sub in a fox box, and a lc7i since I plan on keeping the 8.4ra4.
Install was going good. Gutted the interior and put down some sound deadening. Ran KnuKonceptz wire from the Hu back and from the amps to the doors. Ran power from the battery to a distribution block under the rear seat.
So I turned it on got some music out of the tweeters and rear doors after messing with settings I was getting a little out of the front door mids. Couldn't really get the sub to do much but it was working alittle.
Took the truck to the local shop to tune it. He said something wasn't wired right everytime you adjust the front doors it adjusted the sub and vice versa. So he turned downed all the Gains because he thought I could damage something.
I get it home pop the Hu out check the wiring and I tapped into the correct wires. I did (polarity is crossed on one of them) try to turn everything up to get some audio and I get nothing. I messed with everything I could think of. Checked all the wiring can't figure out what's wrong. I took a Kicker I pulled out and tried touching wires straight from the Hu to the kicker and I get nothing.
I'll try checking the wires from the Hu with a multimeter (I think Ac) if I am getting something there is their anyway to double check to see if instead lc7i without going to audiocontrol? What else should I check? If I wrecked the Hu I wanna get one on the way. Everything works but the audio on the Hu. I'm still using the nav
Thanks to everyone that has helped so far and that helps me get this figured out. I may have bit off more than I can chew with my first build
