voice activated climate control?
hatchet
The Uconnect website claims that the 8.4n has voice activated climate control in the 2013 Laramie. The dealer sais he doesn't think it does. Anyone know for ?sure?
Chewy
Bettendorf IA
V8
I've never heard that before. It'll do things like call someone when BT to a phone and change the radio channel, but I'm pretty sure it won't change CC functions, maybe temp?
RamSport13
Tacoma, WA
I can adjust temperature by Uconnect, but not fan speed or where the air comes out. The 4 commands that I can use with Uconnect on my crewcab's dual climate control are:
"Adjust temperature to 70 degrees"
"Adjust driver's side temperature to 70 degrees"
"Adjust passenger side temperature to 70 degrees"
"Adjust rear temperature to 70 degrees"
Of course replacing the temperature with whatever is desired. I originally found the first 3 commands in the Uconnect manual, but the rear temperature command I figured out by trial and error.
