I was parked one day recently, and noticed that my speedometer started ramping up, all the way to 70 mph at times, with a slight increase in rpms as well. Even stranger, the odometer started ticking off tenths of miles.
Thankfully, these symptoms went away, and now I have my Traction Control and ABS lights on constantly, and no Cruise Control functionality. The lights came on intermittently at first, but now are constant.
My guess is that these are symptoms of speed sensor failure, and also guessing the differential-mounted sensor is the culprit.
I am looking for some confirmation on this if possible, Thanks!
2012 Ram 2wd 4.7l four wheel ABS.
