Etc
RamCares
Michigan
n/a
n/a
Yes they have had my truck for 22 days and are saying they have to replace the engine wiring harness.
Hi chickenhawk454,
If you'd like us to check in or follow up with your dealership, please send a PM with your VIN.
Kori
Ram Social Care Specialist
savage_46
Alaska
6.4 swapped
I had a new HD last year that was throwing etc codes & going into limp in. After a lot of diag & chasing, I found the harness was rubbing on the front of the passenger side head.
chickenhawk454
Tennessee
6.7L CTD
I should get it back next week. Where you able to just repair that section of the harness or did you have to replace the whole thing?
savage_46
Alaska
6.4 swapped
Once I found the spot where the harness was rubbing, I saw a very small area (1/4" opening in the convoluted tubing) & saw a pinhole piercing in the wiring insulation. I opened up the harness & never did find the area of concern again, even after checking diagrams & verifying that I'm looking for the right colored wire. At that point, I opted to replace the harness.
chickenhawk454
Tennessee
6.7L CTD
Yeah the dealership ended up putting a new wiring harness in it.
Neelyy4
Jewel Oregon
Having the same issues with my 2011, I've replaced (tps),(aps),(pcm) and even bought a new battery. After all that it hasn't changed a bit,same exact problem. Frustrating
RAM BLKOUT
South Texas
Anyone ever get this problem fixed. I’m living in that electrical **** stormyself
