RAndersen
- Dec 22, 2015
- 8
- 0
- 2010
- Hemo 5.7
Hey all,
I was told to swing by these forums by a fellow co worker and dodge owner. I did some research on the issues with the TIPM and headlights.
Here's my story. Theres a TL;DR(too long;didnt read) summary at the bottom.
Purchased my truck in Sept 14', installed Retroshops HID kit that came with a harness to lower the amps that go into the TIPM so nothing goes wrong. A year goes by without any issues whatsoever until early December last year, when driver side low beam goes out. I quickly order new bulbs and sen by HID kit for testing to ensure nothing is wrong with the kit. I installed my old bulbs, the problem seemed to persist.
Retroshop says the kit is fine and everything works perfectly, as it should for only being a little over year old. Fast forward to December 27th, my father in law, who is an electrician, helps me trouble shoot the electrical problems I was having. We narrowed it down to the ground wire on the truck's side headlight assembly connection. To test if it was really the problem, we spliced the wire and attached a thicker wire on it and grounded it on the truck at a ground point. Headlight low beams and high beams worked!
Fast forward to mid January, both headlights go out no. Only things working is parking lights and fog lights, which to my surprised to this day I haven't even been pulled over but Omaha cops are pretty relaxed.
So I have taken the truck to the stealership and quoted me $1550(military discount) to replace the TIPM, electrical wiring, and labor. He mentioned that the HID kit could've pumped out to many amps to the TIPM and over time, burned it out. Is this true?
Reading all the problems everyone else seems to be having here AFTER they receive the new TIPM, what can I do to ensure this problem doesnt happen again? I will not be installing HID even though I don't think this seems to be the root cause. Maybe it was the ground connection to begin with. The father in law and I were able to re create the problem every time with whatever we did.
TL;DR- driver side low beams went out along with high beams and only parking and fog lights working. established new ground wire to truck; everything worked. A few weeks later, both headlights went out. Giving into the dealership. TIPM needs replacing. Need preventative measures to not let this happen again.
Thanks in advanced!
Thanks in advanced!
