Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
3rd Gen Technical Service Bulletins
This is a discussion on 3rd Gen Technical Service Bulletins within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! Technical Service Bulletins are put out by the manufacture to provide OEM service ...
Closed Thread
Old 11-10-2010, 05:59 PM   #1 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default 3rd Gen Technical Service Bulletins
Technical Service Bulletins are put out by the manufacture to provide OEM service technicians with a procedure to resolve problems. TSB's are registered with the US Government and below is an export of that data.
To search for TSB's for your specific Year / Model please see: ODI - Office of Defects Investigation
The included information does not have step by step "how-to" or part numbers. It is simply a notification that there was a problem with a specific component.
TSB's are performed by Dodge dealerships for no cost if the component is still covered under warranty. For the most part if your vehicle is outside the bumper-to-bumper warranty the service will be billable. Some individual components have an extended service warranty due to a specific failure. Speak with your local Dodge service representative to check the status of your vehicle.
The "SERVICE BULLETIN #" or "REPLACEMENT SB#" numbers provided are provided by Dodge and should be searchable by your Dodge service representative.
__________________
Owner & Service Manuals for many years: www.scribd.com/lilfroger/shelf
lilfroger is offline
Old 11-10-2010, 06:01 PM   #2 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 2200102: Chrome wheel
Service bulletin #: 2200102
replacement sb#: 2200101
nhtsa item #: 634082
date: 20020311
failing component: 980000 unknown or other
make: Dodge
model: Ram
year: 2003
date created: 20020927
description of summary: Chrome wheel care. *slc
__________________
Old 11-10-2010, 06:02 PM   #3 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1801902a: Engine control module (ecm) from cummins
Service bulletin #: 1801902a
replacement sb#: 1801902
nhtsa item #: 634112
date: 20020904
make: Dodge
model: Ram
year: 2003
description of summary: Revision of flash process for new engine control module (ecm) from cummins. *slc this bulletin supersedes bulletin 18-019-02 dated june 17, 2002. *tt
__________________
Old 11-10-2010, 06:03 PM   #4 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1802002: Flash programming failure recovery
Service bulletin #: 1802002
replacement sb#: 183298
nhtsa item #: 634272
date: 20020624
make: Dodge
model: Ram
year: 2003
date created: 20020928
description of summary: Flash programming failure recovery. *slc
__________________
Old 11-10-2010, 06:04 PM   #5 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default TSB 1802402: Incorrect VIN number
Service bulletin #: 1802402
replacement sb#:
Nhtsa item #: 635689
date: 20020812
failing component: 355100 EQUIPMENT: OTHER : LABELS
make: Dodge
model: Ram
year: 2003
date created: 20021030
description of summary: Some 2003 vehicles equipped with dual rear wheels, built prior to july 15, 2003, may have an incorrect number as the sixth character of the vin. *tt
__________________
Old 11-10-2010, 06:06 PM   #6 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default TSB 2100202: Diagnostic Prodcedures for Transmissions
Service bulletin #: 2100202
replacement sb#:
Nhtsa item #: 635721
date: 20020708
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2003
description of summary: Subject regarding revision in diagnostic procedures and labor operation times for re transmissions. *tt
__________________
Old 11-10-2010, 06:07 PM   #7 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 300202: Synthetic rear axle lubricant
Service bulletin #: 300202
replacement sb#:
Nhtsa item #: 635730
date: 20020701
failing component: 100000 power train
make: Dodge
model: Ram
year: 2003
description of summary: Information on the use of synthetic rear axle lubricant. *tt
__________________
Old 11-10-2010, 06:08 PM   #8 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1400202: Tampering with vp44 fuel pump
Service bulletin #: 1400202
replacement sb#:
Nhtsa item #: 635734
date: 20020701
failing component: 070000 fuel system, gasoline
make: Dodge
model: Ram
year: 2003
description of summary: Information on tampering with vp44 fuel pump on cummins diesel engines. *tt
__________________
Old 11-10-2010, 06:10 PM   #9 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default TSB 28: ENGINE COOLING FAN and PULLY
Service bulletin #: 28
replacement sb#:
Nhtsa item #: 10000331
date: 20021001
failing component: 062200 engine and engine cooling:cooling system:fan
make: Dodge
model: 2500, 3500
year: 2003
date created: 20030224
description of summary: Customer satisfaction notification to tighten the diesel engine cooling fan which may become loose and separate from the pulley. *tt
__________________
Old 11-10-2010, 06:11 PM   #10 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 2021: 5.7l engine valve spring breakage
Service bulletin #: 2021
replacement sb#:
Nhtsa item #: 10000442
date: 20021104
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram
year: 2003
date created: 20030227
description of summary: 5.7l engine valve spring breakage. *tt
__________________
Closed Thread
Bookmarks
Tags
dodge ram tsb's, ram codes, ram tsb's, trouble codes
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2nd Gen Service Manual Bigtman07 2nd Gen DIY 1 05-24-2011 01:30 PM
4th Gen Technical Service Bulletins lilfroger Tech Info 11 11-08-2010 03:00 PM
2003 Ram Service Manual Bigtman07 Tech Info 11 10-22-2010 04:05 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
