3rd Gen Technical Service Bulletins
Discussion in 'Tech Info' started by lilfroger, Nov 10, 2010.
Thread Status:
Not open for further replies.
  1. lilfroger
    lilfroger Senior Member
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Technical Service Bulletins are put out by the manufacture to provide OEM service technicians with a procedure to resolve problems. TSB's are registered with the US Government and below is an export of that data.
    To search for TSB's for your specific Year / Model please see: ODI - Office of Defects Investigation
    The included information does not have step by step "how-to" or part numbers. It is simply a notification that there was a problem with a specific component.
    TSB's are performed by Dodge dealerships for no cost if the component is still covered under warranty. For the most part if your vehicle is outside the bumper-to-bumper warranty the service will be billable. Some individual components have an extended service warranty due to a specific failure. Speak with your local Dodge service representative to check the status of your vehicle.
    The "SERVICE BULLETIN #" or "REPLACEMENT SB#" numbers provided are provided by Dodge and should be searchable by your Dodge service representative.
  2. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2200102: Chrome wheel
    Service bulletin #: 2200102
    replacement sb#: 2200101
    nhtsa item #: 634082
    date: 20020311
    failing component: 980000 unknown or other
    make: Dodge
    model: Ram
    year: 2003
    date created: 20020927
    description of summary: Chrome wheel care. *slc
  3. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1801902a: Engine control module (ecm) from cummins
    Service bulletin #: 1801902a
    replacement sb#: 1801902
    nhtsa item #: 634112
    date: 20020904
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Revision of flash process for new engine control module (ecm) from cummins. *slc this bulletin supersedes bulletin 18-019-02 dated june 17, 2002. *tt
    r mc likes this.
  4. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1802002: Flash programming failure recovery
    Service bulletin #: 1802002
    replacement sb#: 183298
    nhtsa item #: 634272
    date: 20020624
    make: Dodge
    model: Ram
    year: 2003
    date created: 20020928
    description of summary: Flash programming failure recovery. *slc
  5. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    TSB 1802402: Incorrect VIN number
    Service bulletin #: 1802402
    replacement sb#:
    Nhtsa item #: 635689
    date: 20020812
    failing component: 355100 EQUIPMENT: OTHER : LABELS
    make: Dodge
    model: Ram
    year: 2003
    date created: 20021030
    description of summary: Some 2003 vehicles equipped with dual rear wheels, built prior to july 15, 2003, may have an incorrect number as the sixth character of the vin. *tt
  6. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    TSB 2100202: Diagnostic Prodcedures for Transmissions
    Service bulletin #: 2100202
    replacement sb#:
    Nhtsa item #: 635721
    date: 20020708
    failing component: 103000 power train:automatic transmission
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Subject regarding revision in diagnostic procedures and labor operation times for re transmissions. *tt
  7. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 300202: Synthetic rear axle lubricant
    Service bulletin #: 300202
    replacement sb#:
    Nhtsa item #: 635730
    date: 20020701
    failing component: 100000 power train
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Information on the use of synthetic rear axle lubricant. *tt
  8. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 1400202: Tampering with vp44 fuel pump
    Service bulletin #: 1400202
    replacement sb#:
    Nhtsa item #: 635734
    date: 20020701
    failing component: 070000 fuel system, gasoline
    make: Dodge
    model: Ram
    year: 2003
    description of summary: Information on tampering with vp44 fuel pump on cummins diesel engines. *tt
  9. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    TSB 28: ENGINE COOLING FAN and PULLY
    Service bulletin #: 28
    replacement sb#:
    Nhtsa item #: 10000331
    date: 20021001
    failing component: 062200 engine and engine cooling:cooling system:fan
    make: Dodge
    model: 2500, 3500
    year: 2003
    date created: 20030224
    description of summary: Customer satisfaction notification to tighten the diesel engine cooling fan which may become loose and separate from the pulley. *tt
  10. lilfroger
    1,224
    Aug 29, 2010
    Ram Year:
    2006
    Engine:
    5.9 CTD
    Tsb 2021: 5.7l engine valve spring breakage
    Service bulletin #: 2021
    replacement sb#:
    Nhtsa item #: 10000442
    date: 20021104
    failing component: 061000 engine and engine cooling:engine
    make: Dodge
    model: Ram
    year: 2003
    date created: 20030227
    description of summary: 5.7l engine valve spring breakage. *tt
Thread Status:
Share This Page
