3rd Gen Technical Service Bulletins
Status
Not open for further replies.
L
lilfroger
5.9 CTD
Tsb 1801403: Erroneous diagnostic trouble codes (dtc) p0300 - p0309
Service bulletin #: 1801403
replacement sb#:
Nhtsa item #: 10001523
date: 20030404
failing component: 110000 electrical system
make: Dodge
model: Ram
year: 2003
date created: 20030605
description of summary: Malfunction indicator lamp (mil) illumination, erroneous diagnostic trouble codes (dtc) p0300 - p0309. *tt
L
lilfroger
5.9 CTD
Tsb 1801503: No shift out of third gear condition
Service bulletin #: 1801503
replacement sb#:
Nhtsa item #: 10001524
date: 20030404
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2003
description of summary: Powertrain control module (pcm) shift quality improvements for a no shift out of third gear condition. *tt
L
lilfroger
5.9 CTD
Tsb 3010: Scored 3.7l engine crankshaft
Service bulletin #: 3010
replacement sb#:
Nhtsa item #: 10001533
date: 20030424
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram
year: 2003
date created: 20030606
description of summary: Scored 3.7l engine crankshaft. *tt
L
lilfroger
5.9 CTD
Tsb 801903: Lamp out indicator with aftermarket pick up box installation
Service bulletin #: 801903
replacement sb#:
Nhtsa item #: 10002039
date: 20030620
make: Dodge
model: Ram
year: 2003
date created: 20030812
description of summary: Lamp out indicator with aftermarket pick up box installation. *tt
L
lilfroger
5.9 CTD
Tsb 2301603: Buzzing or vibrating sound
Service bulletin #: 2301603
replacement sb#:
Nhtsa item #: 10002050
date: 20030613
failing component: 162000 structure:body
make: Dodge
model: Ram
year: 2003
description of summary: Buzzing or vibrating sound coming from the front of the vehicle. *tt
L
lilfroger
5.9 CTD
TSB 2301803: HEATER A/C BLOWER Noise
Service bulletin #: 2301803
replacement sb#:
Nhtsa item #: 10002052
date: 20030613
make: Dodge
model: Ram
year: 2003
description of summary: Whistling sound may be present coming from the front of the instrument panel near the bottom of the windshield when the heater a/c blower is on. *tt
L
lilfroger
5.9 CTD
Tsb 2400403: Defrost door inoperative
Service bulletin #: 2400403
replacement sb#:
Nhtsa item #: 10002053
date: 20030613
failing component: 353600 equipment:electrical:air conditioner
make: Dodge
model: Ram
year: 2003
description of summary: Defrost door inoperative. *tt
L
lilfroger
5.9 CTD
Tsb 1800503a: Transmission shift/speed control improvements
Service bulletin #: 1800503a
replacement sb#: 1800503
nhtsa item #: 10002190
date: 20030425
failing component: 180000 vehicle speed control
make: Dodge
model: Ram pickup
year: 2003
date created: 20030815
description of summary: Transmission shift/speed control improvements/possible malfunction indicator lamp illumination. *tt
L
lilfroger
5.9 CTD
Tsb 1801303: (etc) light illumination and/or poor idle quality
Service bulletin #: 1801303
replacement sb#: 1803502
nhtsa item #: 10002286
date: 20030328
make: Dodge
model: Ram
year: 2003
date created: 20030820
description of summary: Malfunction indicator lamp and/or engine throttle control (etc) light illumination, diagnostic trouble codes (dtcs), and/or poor idle quality. *tt
L
lilfroger
5.9 CTD
Tsb 800403: Erroneous indicator lamps
Service bulletin #: 800403
replacement sb#:
Nhtsa item #: 10002292
date: 20030314
make: Dodge
model: Ram
year: 2003
description of summary: Electro mechanical instrument cluster - erroneous indicator lamps. *tt
L
lilfroger
5.9 CTD
Tsb 600103: Rattle sound from transmission when idling
Service bulletin #: 600103
replacement sb#:
Nhtsa item #: 10002395
date: 20030516
failing component: 101000 power train:clutch assembly
make: Dodge
model: Ram
year: 2003
date created: 20030827
description of summary: Rattle sound from transmission when idling. *tt
L
lilfroger
5.9 CTD
Tsb 3002: Transmission shift/speed control improvements
Service bulletin #: 3002
replacement sb#:
Nhtsa item #: 10002447
date: 20030516
failing component: 103100 power train:automatic transmission:control module (tcm, pcm)
make: Dodge
model: Ram
year: 2003
date created: 20030829
description of summary: Service action 03-002 - inoperative software, service bulletin #18-005-03 rev a, flash: Transmission shift/speed control improvements/possible malfunction indicator lamp (mil) illumination. *tt
L
lilfroger
5.9 CTD
Tsb c17: Pcm will not detect a transmission governor pressure sensor
Service bulletin #: C17
replacement sb#:
Nhtsa item #: 10002448
date: 20030501
make: Dodge
model: Ram pickup
year: 2003
description of summary: The powertrain control module (pcm) was programmed with errors in the automatic transmission diagnostic information. As a result, the pcm will not detect a transmission governor pressure sensor problem, or illuminate the malfunction indicator light (mil) if this sensor fails in the future. The powertrain control module (pcm) must be reprogrammed (flashed). *tt
L
lilfroger
5.9 CTD
Tsb 1800503b: Transmission shift/speed control improvement
Service bulletin #: 1800503b
replacement sb#: 1800503a
nhtsa item #: 10003415
date: 20030704
make: Dodge
model: Ram pickup
year: 2003
date created: 20031020
L
lilfroger
5.9 CTD
Tsb 1802703: Diagnostic trouble codes (dtc) p2638/p0700
Service bulletin #: 1802703
replacement sb#:
Nhtsa item #: 10003418
date: 20030704
make: Dodge
model: Ram pickup
year: 2003
description of summary: No throttle response, lack of power while towing and diagnostic trouble codes (dtc) p2638/p0700. *tt
L
lilfroger
5.9 CTD
Tsb 3014: Pcm electrical connector seal
Service bulletin #: 3014
replacement sb#:
Nhtsa item #: 10003520
date: 20030829
make: Dodge
model: 1500, 2500, 3500
year: 2004
date created: 20031022
description of summary: Service action 03014 - powertrain control module (pcm) electrical connector seal inspection/repair procedure. *tt
L
lilfroger
5.9 CTD
Tsb 1800503c: Transmission shift / speed control improvements
Service bulletin #: 1800503c
replacement sb#: 1801304
nhtsa item #: 10003540
date: 20030330
failing component: 100000 power train
make: Dodge
model: Ram pickup
year: 2003
date created: 20031023
description of summary: Transmission shift / speed control improvements / possible malfunction indicator lamp illumination. *tt
L
lilfroger
5.9 CTD
Tsb 1803003: Cummins engine control module procedure
Service bulletin #: 1803003
replacement sb#: 1801902a
nhtsa item #: 10003544
date: 20030829
make: Dodge
model: Ram
year: 2003
description of summary: Generic cummins engine control module (pcm) procedure. *tt
L
lilfroger
5.9 CTD
Tsb 803103: Powertrain control module (pcm) connector
Service bulletin #: 803103
replacement sb#:
Nhtsa item #: 10004537
date: 20031031
make: Dodge
model: Ram
year: 2003
date created: 20031218
description of summary: Water may enter the powertrain control module (pcm) connector causing corrosion of electrical terminals on the pcm. Sets malfunction indicator light. *tt
L
lilfroger
5.9 CTD
Tsb 1803003a: Cummins engine control module procedure
Service bulletin #: 1803003a
replacement sb#: 1803304
nhtsa item #: 10004538
date: 20040820
make: Dodge
model: Ram
year: 2003, 2004
description of summary: Generic cummins engine control module (pcm) procedure. *tt this bulletin replaced 18-030-03. *tt this bulletin replaced 18-030-03a dated 10/17/03. To also include 2005 ram truck. *tt
Status
