3rd Gen Technical Service Bulletins
Status
Not open for further replies.
L
lilfroger
5.9 CTD
Tsb 1803703: Erroneous diagnostic trouble code p0116, p2172, p2173
Service bulletin #: 1803703
replacement sb#:
Nhtsa item #: 10004541
date: 20031010
failing component: 060000 engine and engine cooling
make: Dodge
model: Ram
year: 2003
date created: 20031218
description of summary: Malfunction indicator lamp illumination, erroneous diagnostic trouble code (dtc) p0116, p2172, p2173. *tt
L
lilfroger
5.9 CTD
Tsb 500803: Brake shudder or vibration
Service bulletin #: 500803
replacement sb#: 500304
nhtsa item #: 10005294
date: 20040608
failing component: 030000 service brakes, hydraulic
make: Dodge
model: Ram
year: 2003
date created: 20040219
description of summary: Brake shudder or vibration. *tt
L
lilfroger
5.9 CTD
Tsb 30: Pcm electrical connector seal
Service bulletin #: 30
replacement sb#:
Nhtsa item #: 10005354
date: 20031101
failing component: 103100 power train:automatic transmission:control module (tcm, pcm)
make: Dodge
model: Ram
year: 2004
date created: 20040223
description of summary: Powertrain control module (pcm) electrical connector seal customer satisfaction notification no. C30. *tt
L
lilfroger
5.9 CTD
TSB 0300104A: Axle Fluid Level
Service bulletin #: 0300104a
replacement sb#: 300104
nhtsa item #: 10005561
date: 20040511
failing component: 106000 power train:axle assembly
make: Dodge
model: Ram
year: 2004
date created: 20040303
description of summary: The axles are located considerably higher that the actual fluid level. Filling the axle until the fluid comes out of the fill hole will over fill the axle, which could cause fluid foaming. *mn *tt
L
lilfroger
5.9 CTD
Tsb 2300104: Bug deflector wind whistle
Service bulletin #: 2300104
replacement sb#:
Nhtsa item #: 10005601
date: 20040113
failing component: 162000 structure:body
make: Dodge
model: Ram
year: 2003
date created: 20040305
description of summary: Bug deflector wind whistle. *tt
L
lilfroger
5.9 CTD
TSB 4001: Exhaust Clamp crack
Service bulletin #: 4001
replacement sb#:
Nhtsa item #: 10005612
date: 20040126
failing component: 063000 engine and engine cooling:exhaust system
make: Dodge
model: Ram
year: 2004
date created: 20040308
description of summary: Some trucks equipped with the new high output diesel engine may have been built with exhaust clamps with welds that could crack and separate. Rapid response transmittal 04-001. *tt
L
lilfroger
5.9 CTD
Tsb 2100104: Transmission solenoid replacement
Service bulletin #: 2100104
replacement sb#:
Nhtsa item #: 10005978
date: 20040210
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2004
date created: 20040405
description of summary: Transmission solenoid replacement. *tt
L
lilfroger
5.9 CTD
Tsb 1800704: Ctd engine and engine cooling
Service bulletin #: 1800704
replacement sb#:
Nhtsa item #: 10005980
date: 20040224
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram
year: 2004
description of summary: White smoke, engine stumble/misfire, or flat spot in engine performance. *tt
L
lilfroger
5.9 CTD
Tsb 1800604a: Generic pcm procedure
Service bulletin #: 1800604a
replacement sb#: 1800604b
nhtsa item #: 10005981
date: 20040406
make: Dodge
model: Ram
year: 2004
description of summary: Generic powertrain control module (pcm) procedure. *tt *mj this bulletin supersedes bulletin 18-006-04a dated 04/06/2004. *tt
L
lilfroger
5.9 CTD
TSB 1800404: CTD Poor Cab Heat / Slow Engine Warm-Up
Service bulletin #: 1800404
replacement sb#:
Nhtsa item #: 10005983
date: 20040203
make: Dodge
model: Ram
year: 2004
description of summary: Poor cab heat and/or slow engine warm up in cold ambient temperatures. *tt
L
lilfroger
5.9 CTD
Tsb 1800304: Dtc's p0341 and p1757
Service bulletin #: 1800304
replacement sb#: 1804303
nhtsa item #: 10005984
date: 20040203
failing component: 110000 electrical system
make: Dodge
model: Ram
year: 2003, 2004
description of summary: Poor air conditioner performance, slow fuel gauge response, and diagnostic trouble codes (dtc's) p0341 and p1757. *tt
L
lilfroger
5.9 CTD
Tsb 1800204: Dtc's p0335 or p0340
Service bulletin #: 1800204
replacement sb#:
Nhtsa item #: 10005985
date: 20040203
make: Dodge
model: Ram
year: 2004
description of summary: Erroneous diagnostic trouble codes (dtc's) p0335 or p0340 crankshaft or camshaft position lost. *tt
L
lilfroger
5.9 CTD
Tsb 0900604: Low engine oil pressure at start u
SERVICE BULLETIN #: 0900604
REPLACEMENT SB#:
NHTSA ITEM #: 10005989
DATE: 20040217
FAILING COMPONENT: 061000 ENGINE AND ENGINE COOLING:ENGINE
MAKE: DODGE
MODEL: RAM
YEAR: 2003
DATE CREATED: 20040405
DESCRIPTION OF SUMMARY: LOW ENGINE OIL PRESSURE AT START UP IN TEMPERATURES BELOW FREEZING. *TT
Repair Procedure:
1. Using the procedures outlined in the 2003 Ram Truck Service Manual, publication number 81-370-03059, section 9 page 218, Remove thew engine oil pump and pick up tube.
2. Check the oil pressure relief valve for any irregularities that could cause the valve to stick open. Repair as necessary
3. Install the new pick up tube, p/n 53021522AD.
L
lilfroger
5.9 CTD
Tsb 0900504: Growling sound on acceleration
SERVICE BULLETIN #: 900504
REPLACEMENT SB#:
NHTSA ITEM #: 10005990
DATE: 20040217
MAKE: DODGE
MODEL: RAM
YEAR: 2003
DESCRIPTION OF SUMMARY: GROWLING SOUND ON ACCELERATION. *TT
NOTE: This bulletin applies to 1500 Series 4 x 2 vehicles equipped with 4.7L and 3.7L engines.
1. Raise the vehicle on a hoist.
2. Place an adjustable jack stand under the engine to support the engine when the motor mount through bolts removed.
3. Loosen both motor mount through bolts. Leave the nut on the left side mount as this bolt will not be removed. Remove the nut on the right side.
4. Raise the engine with the jack stand until the right side through bolt becomes free. remove the right side bolt. Raise the engine far enough to clear the frame bracket and allow the isolator pad, p/n 55366020AA to be inserted. Insert the isolator on the mount with the Pentastar logo facing the front of the vehicle. Lower the bracket and align the mount with the frame bracket and push the bolt through the isolator and bracket with the threads at the rear.
5. Install the nut and tighten both through bolts to 115 Nm (85 ft. lbs.).
6. Remove the jack stand.
7. Lower the vehicle
L
lilfroger
5.9 CTD
Tsb 44: Transmission cooler line transmit high pressure pulse
Service bulletin #: 44
replacement sb#:
Nhtsa item #: 10006004
date: 20040201
failing component: 103600 power train:automatic transmission:cooling unit and lines
make: Dodge
model: Ram
year: 2003, 2004
date created: 20040406
description of summary: Customer satisfaction no. C44. Transmission cooler line on certain vehicles can transmit high pressure pulses when the vehicle is operated at heavy loads. *tt
L
lilfroger
5.9 CTD
Tsb 42: Pcm electrical connectors
Service bulletin #: 42
replacement sb#:
Nhtsa item #: 10006005
date: 20040201
make: Dodge
model: Ram
year: 2003
description of summary: The powertrain control module (pcm) electrical connectors on certain trucks may allow water to enter into the connectors. Water and the resulting corrosion in a pcm connector can cause the speed control and/or transmission overdrive funct
L
lilfroger
5.9 CTD
Tsb 1801004: Dtc's p0403, p0404, p0405, p0406
SERVICE BULLETIN #: 1801004
REPLACEMENT SB#:
NHTSA ITEM #: 10006449
DATE: 20040302
FAILING COMPONENT: 110000 ELECTRICAL SYSTEM
MAKE: DODGE
MODEL: RAM
YEAR: 2004
DATE CREATED: 20040503
DESCRIPTION OF SUMMARY: MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION DIAGNOSTIC TROUBLE CODES (DTC'S) P0403, P0404, P0405, P0406. *TT
NOTE: This bulletin applies to DR and HB vehicles equipped with a 5.7L engine (sales code EZA) built on or before February 29, 2004 (MDH 0229XX).
L
lilfroger
5.9 CTD
Tsb 1801704: Driveability and obd ii monitor improvements. Flash. 3.7l.
Service bulletin #: 1801704
replacement sb#: 1801704a
nhtsa item #: 10006883
date: 20040615
make: Dodge
model: Ram
year: 2004
date created: 20040518
description of summary: Driveability and obd ii monitor improvements. Flash. 3.7l. *tt
L
lilfroger
5.9 CTD
Tsb 2301104: Bug deflector loose/rattling
SERVICE BULLETIN #: 2301104
REPLACEMENT SB#:
NHTSA ITEM #: 10006887
DATE: 20040420
FAILING COMPONENT: 162000 STRUCTURE:BODY
MAKE: DODGE
MODEL: RAM
YEAR: 2003, 2004
DATE CREATED: 20040518
DESCRIPTION OF SUMMARY: BUG DEFLECTOR LOOSE/RATTLING. *TT
NOTE: This Bulletin Applies To Vehicles Equipped With A Factory Installed Bug Deflector, Sales Code MXB.
Repair Procedure:
Remove the original fasteners and install new fasteners, p/n 06508197AA.
L
lilfroger
5.9 CTD
Tsb 4012: Ctd block freeze plugs
Service bulletin #: 4012
replacement sb#:
Nhtsa item #: 10006893
date: 20040423
make: Dodge
model: Ram
year: 2004
description of summary: Some trucks equipped with cummins diesel engines were built with engine block freeze plugs, which may not have sufficient interference fit to the block. *tt
Status
