05MachoWagon
- Mar 23, 2015
- 2
- 0
- 2005
- Hemi 5.7
Alright for starters I'll spit out what it is, what I've done, and if anyone with more knowledge on this subject chime in; 2005 5.7L, 4x4, 110,000km, I got a bulldog gt tuner from a kid saying "I lost 5th gear" and the tune was on an 09, I called bulldog got the proper tune for it, updates and all, took 10 mins. Plugged her in uploaded the tune, good. 2 days later a duramax flys by on the highway, instinct sets in, goose-er, trans kicks down, shoots up to 5000rpm, 110km an hour, and stops. At that speed, that rpm -no more acceleration with the petal held there for 4-5 seconds. Every once and awhile if mashed the petal, the trans would "bang" and jolt, then immediately down shift and merry on it's way, So I get it home and check the fluid, looks brown.. Yard it into work, throw it on the hoist and change out the filters, and fluid. Spin on included. Get it back together, start it up and it doesnt want to move in gear- level correct. P0700 code, (constant), Drive it 2 blocks with trans slipping, and open it up next day, pound the seal in on the push-in and try again; only has 1st and is slipping past that. Uninstalled the bully dog tune- Next day, new filter and gasket, new fluid, correctly installed (to get that 120psi seal) has 1st, 2nd -should be shift point -slip. Pulled the snap on scan tool out, monitored line pressure all good including in reverse 94psi, shifts 1-2-3 electronically good with scan tool, just not mechanical side. No codes present anymore.
Price on used trans with same mileage: $720.00
Price on brand new 545-RFE from local shop: $2400 my cost
Price on trans shop rebuild/fix "to be figured"
How do I prevent this from happening again?
Should the transmission be "built" with American made parts not Chinese;
Built for the tuner?
The near future I'm looking at a .276 duration cam, and headers, would now be a good time to build the trans to take abuse?
