Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Tech Info
Engine light - Code P0420
This is a discussion on Engine light - Code P0420 within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
I have read that I can use a scanner or oscilloscope to check to see if the O2 sensor is ...
Reply
Old 12-13-2016, 02:21 PM   #1 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Default Engine light - Code P0420
I have read that I can use a scanner or oscilloscope to check to see if the O2 sensor is bad. Is this something an auto repair shop can do, or could my local auto pets store (O'Reilly/AutoZone) could assist with?
Sponsored Ad
Register to remove this ad.
cuevrojamez is offline   Reply With Quote
Old 12-13-2016, 03:00 PM   #2 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: I Am Currently Truck Shopping!
Engine: Who Knows?
Default
Most auto parts stores can read codes and give you a short printout.
__________________
MICHAEL
SUPER MODERATOR
MADDOG is offline   Reply With Quote
Old 12-14-2016, 12:42 AM   #3 (permalink)
Kenworth's Avatar
Ram Year: 2005
Engine: Hemi 5.7
Default
Repair shop can easily scan and fix. OBD II code readers are fairly cheap to buy and would diagnose many P codes.
An O2 sensor is not difficult to switch out depending on its location and wether its siezed. If its siezed a little heat with a torch can free it up usually.
__________________
If you can't Dodge it,....RAM it.
Kenworth is offline   Reply With Quote
Old 12-15-2016, 11:12 AM   #4 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Default
Scanner is reading 2 P0420 codes, I assume 1 for the sensor before and 1 sensor after the cat converter. Is there a way to determine which sensor is bad?
Old 12-15-2016, 02:38 PM   #5 (permalink)
Ram Year: 2004
Engine: 3.7
Default
The P0420 code is typically only for the sensor after the catalytic converter. It is not an "O2 sensor bad" code, it is a catalyst efficiency code which is normally the O2 sensor downstream from the catalytic converter, but it can also be caused by a bad catalytic converter, vacuum leaks, etc.
You can test them with an O-scope. The voltage range should be between .2-.7 volts and if the cat is in good condition, it should stay pretty close to .5 volts after the engine has warmed up fully. You can try to use a voltmeter, but O2 sensors can switch voltage very rapidly and most voltmeters can't read the changes that fast, so it will average them out.
Bullitt5339 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
P0420 code Daytona 1500 Engine & Performance 3 10-22-2016 11:55 PM
Help with p0420 code OGsohcHondaLOVE Engine & Performance 4 01-30-2015 08:08 PM
check engine light on but no code on dash MossyOakRam Engine & Performance 2 07-22-2014 09:41 AM
Check Engine Light Code P0933 matt_bon Engine & Performance 16 07-05-2014 02:18 PM
2005 1500 5.7L with a P0420 Code... lil help? coastemac Tech Info 11 05-03-2013 04:50 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
