Aluminum
- Jun 1, 2013
- 28
- 2
- 1997 Dodge Ram 2500
- 5.9L Magnum V8
First Problem Is My ABS And Brake Light Are On. I Don't Have An ABS Code Reader To Read The Code. Any Suggestions?
Second Problem My Check Engine Light Is On I Am Getting "P0754" Shift Solenoid A Electrical, What Do I Need To Check And Replace To Fix This? Or Do I Need To Replace The Solenoid?
Third Problem When I Put My Truck In 4Low The 4WD Shifter Shakes Horrible And Makes A Grinding Noise Under Neath The Truck. Any Suggestions?
