V10, poor power, rushing air sound.
dgbirky
8.0 V10
2000 v10. the truck idles fine. no check engine light. when I step on the gas I hear a massive rushing sound, and there is no power from te engine. The engine acts as if either the exhaust is plugged or I am stepping on the brake while flooring the accelerator. if I idle and slowly accelerate keeping it under 2000 RPM I can slowly get up to speed but again no power and the rushing sound continues. 175000 on the truck.
dudeman2009
Magnum 360
Have you tried putting it into manual 1 on the transmission? Could be a combo issue. Worn out bands will cause lack of power. Rushing sounds could be loose anything before the throttle body, i'd give it a good check over. I dont know if the v10s have the same airhats as the 5.2 and 5.9s. However when I got my truck there was no airhat gasket, lots of rushing air and whistling from that.
Depending on the rushing, you could have a bad fan clutch, but I would check the air intake first.
joepizuro
Magnum v10
How old is your cat converter?
muttmutt
2016 Ram Sport
+1 on the Catalytic Converter. Sounds like it may be plugged
CVX20
Ont,Ca.
2019 Classic Express
Another vote for a plugged converter!
Florida
Mag V10,Mag V8
No you are all wrong...do like I did!!My (22 at the time) step son borrowed my truck ,'01 Dodge 2500 4x4 V10 488ci...for 45min one way drive to work 5 days a week...for three months!!Finally got it back he told me "You might need a tranny rebuild".Truck had no power,could hardly get out of its own way!!So I took it to a Tranny shop said "I think it needs a rebuild,has no power,no get-up-n-go".Guy said OK $1250 for the rebuild...I was like OK.4 days after rebuild got my truck back tranny shop guy told me "Oh...your truck got no power...no get-up-n-go...needs catalytic converter">I was like...DOH<DOH<DOH<No efin chit!!How 'bout that!! Made my slow ass way down to another shop...they charged me $100 to lop out the Cat...throw in a pipe...there ya go!!!:crazy:
Florida
Mag V10,Mag V8
Yes I feel like a idiot...but that was before I found this Forum...where people actually try/do help a guy out!!
Florida
Mag V10,Mag V8
Yes I feel like a idiot but that was way before I found this Forum...you guys are great.
joepizuro
Magnum v10
Guessing OP figured out the problem. When you let everyone know what the problem ended up being it helps users who use the forum search or Google.
