Poor acceleration
rzr6-4
nebraska
If it’s cats. The tail pipe will sound like it’s hissing when you rev it
Hissing can be a sign but not a for sure thing. Mine has a little bit of a hiss and I assure you they are not clogged.
Trashy2121
Get a build sheet and see what the rear end gearing is. A hellcat geared too high wont spin tires.
tnctx02
tnctx02
2017 RAM SLT
3.6L Pentastar V6
It doesn't accelerate from a stop hardly at all and I have to floor it to make it go after it gets speed up. This is why I am stumped.
Engine revs just fine when in park. Sounds good idling. If it had a carb I would say it is loading up like too much gas then finally goes.
Thanks for the reply
tnctx02
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Maybe air filter. Not sure if yours has trip reset button ? If it does you could hold button down & turn key to on .(Not start) & the odometer should give codes.
I change the air filter every oil change which is 7500 miles. I will try your recommendation too!
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Firstly, I own a 2013 Ram Tradesman with the 4.7L engine. I inherited from my father. It has a few issues I am working on.
I don't have much money at the moment, going through a divorce, so I am hoping with all the experience here someone can help figure this out.
It accelerates so slowly and will not even spin the tires. I managed to change the plugs before I had shoulder surgery but it made no difference.
To me it feels like it is loading up then finally it accelerates. But I do not know what to do next.
The truck drives and seems to run good otherwise. Engine idles good.
Anyone have any ideas? Thanks in advance for any help.
You are probably geared 3:55.
My 2014 5.7 Hemi was geared 3:55 with the 6-speed transmission.....it was a dog off the line & would not spin wheels.
The 8-speed transmission are a huge improvement with the very low 1st gear.
Even with a tune on the 6-speed it still was bad off the line.
Only thing you can do is live with it if you cannot afford to change the gear ratio to 4:56 in the differentials which is what I did along with a stall convertor & it was a big improvement.
The 8-speed swap is another option but that is costly also.
crackerjack1957
Going from a 33 inch to a 30 tire would help slightly but that's another expensive & speedometer recalibrate
tnctx02
tnctx02
2017 RAM SLT
3.6L Pentastar V6
The build sheet says 3.55 for the rear diff. I might have made it even worse by going with the 6" lift and 35" BFG tires!
Will look around to see if anyone else has done the swap before moving forward that direction.
I appreciate the reply, it was not an angle I had looked at.
There's your issue right there,dump the lift and tires and you'll probably have alot more power out of your 4.7.Whatever possessed you to think that little 4.7 will pull heavy a$$ed 35's and be happy.Even if you regear it to 4.56's which is gonna take a pile of money,as you'll need to find the earlier AAM diff and all the brackets/driveshaft etc. to bolt it in place then swap the gears in both diffs to 4.56's,it's still not going to have all that much power with a 6" lift and 35's.
It's a tiny engine pulling a heavy truck,and you really compounded the problem by lifting it and hanging heavy tires on it,i'll lay odds there's nothing wrong with the truck,that isn't caused by you
crackerjack1957
Your actual gear ratio probably about 3:31 now with the taller tires
Should find several on here that have done a gear change.
crackerjack1957
Uh.....you beat me to the post/punch..... LoL
