IrocRam
I just bought a 1997 1500 5.2 auto 4x4 with a roughly 6" fabtech long arm lift. I have to turn the steering wheel pretty far to get it in a straight line and it's somewhat unresponsive. I took it to an alignment shop this morning just to have them check it out because I still have my finger wrapped up and can't mess with it too much (took the end of one of my fingers off with a hammer). Ball joints on the driver side are bad, one tie rod end is bad, and the track bar bushings are bad is what they told me. And the stabalizer bolt is loose because it's not the right one. Everything else they said checked out fine. The track bar is an aftermarket adjustable one but they told me it's not a fabtech one. So if that's the case, how do I determine which bushings I need to replace them? This shop wants over $1000 for parts and labor which I didn't plan on them doing, I just wanted them to diagnose it for me. I plan on doing both sides ball joints and the tie rods when I do the front end work regardless if some stuff is fine for now. Doesn't make sense to tear into it and do half and the other half fail a few months later. It's also a lifted truck so it will be eating through front ends I'm sure.
Do I need to remove the track bar and measure it and then order bushings for that wise track bar from any manufacturers? Or can I just call fabtech and order the bushings that go on the track bar that comes with the 5.5" long arm kit they currently sell? I was also told that fabtech used to do blue suspension parts and about 10 years ago they switched to black ones. Their website only shows a black kit and the one on my truck is blue. The track bar I think is black buts it's kind of dirty. But it's an adjustable one that they claim isn't a fabtech track bar. Just trying to get all my ducks in a row and parts ordered for when my finger heals and I can tear into this.
