Where can i mount a tow hook, or better yet, D ring/mounting plates?
Lethalweapon100
NY
V8 5.9 Magnum
Hey all, I'd like to pick up a set of d rings and mounting brackets for my Ram 2500. Is there any way i can cut out some squares from the front bumper and mount them in there? Any solid point in there, or will they have to dangle off the bottom?
Basically what im asking, where could i mount these rings on the front, or where could i mount a hook under the truck on the frame and how?
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
take a tow hook off a semi (they sell them on ebay) $50 ish and mount it directly to your frame in a good location. you have to get good grade bolts and then i would still throw a couple beads on it too
