squarethumps
- Jul 9, 2016
- 24
- 0
- 1996
- 318
Hello all.
Can anyone please fill me in on exactly how cam shaft bearings are sized ?
I need to buy a new cam. One of the lobes on mine is kind of chewed up on one spot. The roller lifer that was riding on it doesn't appear to have any damage. I can't justify putting everything back together with that cam.
I would like to put a modified cam what gives me the most horsepower without having to change anything else. ( throttle body etc ) I was told this is possible, but I don't know what size cam to order, and I don't understand about the cam bearing size especially in an engine that was already rebuilt once. ( the pistons are 0.060 over and the main and piston bearings are 0.010 under ? is it ? )
Can someone please explain how cam bearings are sized ?
It should be noted that I saw no other wear on any of the other bearings ( no copper showing at all ) no ridges on top of the piston bore. It was like the engine was rebuilt and only ran for 10,000 miles.
However, oil was being pushed out of like every gasket, the rear main, etc .. I don't understand why oil was being pushed out from everywhere but the engine looked like brand new on the inside.
Regardless, I'd appreciate all the infromation I can get about how cam bearings are sized and such and how I can understand what cam to buy.
Thanks very much.
Thanks very much.
