Hi Joe,
For your application, you would need our Stage 5. This system comes with 2 Extreme HD High output fans, 2 hand formed, hand tig welded aluminum shrouds and 2 completely separate extreme fan control units, 1 for each fan assembly. Aluminized coated blades for high under the hood temperatures to deflect heat and hold shape. All relays, fuses, wiring, mounting kits etc.
Basically your truck will run 2 completely individual fan systems that you will be able to control with 2 different controllers. It is the only system on the market like it and it will allow you to set 2 different temperatures and allow the fans to be completely independent of each other, giving you complete control and allowing each fan to have its own power supply, its own relay assembly and to run at its own set temperature. For example, this gives you the ability to set the first fan system at 200 degrees and then set the second fan system to come on at 220 degrees. What this does for you is it will allow your truck to be cooled down by 1 fan system as your daily driver, and then only when your engine needs the second larger fan to turn on, it will. We call this our Smart System.
Price is $450 with free shipping and all custom shroud systems take approx 3-5 days to build and then ship out after order is placed.
If this is something you are interested in or have any questions let us know. Here is the link: Dodge Ram 2500 Extreme Stage 5 | FF Dynamics
Thanks!
FFD
