Electric fans.. kit or DIY?
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
Looking into doing an electric fan conversion. I like the FF dynamics kit at $275, but their kit looks like something i could piece together myself for half the price.. anyone on here run E-fans? i know its fairly simple to do. You just have to run the correct wiring which is pretty plug and play.
joepizuro
Magnum v10
they told me I need the extreme one for my v10.. $475
IrocRam
Phoenix, Az
Lots of people use the Ford Tarus fans. Not sure why but I have seen people with all kinds of vehicles use them including these trucks. I don't exactly know why they are such a popular choice but I'm guessing it's a combination of how many were made and the size of it.
BBartow
New Port Richey, Florida
5.9L Magnum
FFD makes some of the best quality fans out there. For $275 its a fair price compared to piecing together your own setup.
They move a lot of air and are cheap at junkyards that's it. Downside they draw a **** ton of amps. 60A+ on startup and 30A+ fullspeed.
dapepper9
Iowa/Nebraska Border
5.9L V8
I accidentally won a Chevy HHR fan on an eBay auction for $45. Big enough that the Dakota guys like em
joepizuro
Magnum v10
Here's what I was told by them regarding my 98 Ram 2500 v10 4x4 Fullsize with plow and tow. Seems like a lot of money to me lol
Hi Joe,
For your application, you would need our Stage 5. This system comes with 2 Extreme HD High output fans, 2 hand formed, hand tig welded aluminum shrouds and 2 completely separate extreme fan control units, 1 for each fan assembly. Aluminized coated blades for high under the hood temperatures to deflect heat and hold shape. All relays, fuses, wiring, mounting kits etc.
Basically your truck will run 2 completely individual fan systems that you will be able to control with 2 different controllers. It is the only system on the market like it and it will allow you to set 2 different temperatures and allow the fans to be completely independent of each other, giving you complete control and allowing each fan to have its own power supply, its own relay assembly and to run at its own set temperature. For example, this gives you the ability to set the first fan system at 200 degrees and then set the second fan system to come on at 220 degrees. What this does for you is it will allow your truck to be cooled down by 1 fan system as your daily driver, and then only when your engine needs the second larger fan to turn on, it will. We call this our Smart System.
Price is $450 with free shipping and all custom shroud systems take approx 3-5 days to build and then ship out after order is placed.
If this is something you are interested in or have any questions let us know. Here is the link: Dodge Ram 2500 Extreme Stage 5 | FF Dynamics
Thanks!
FFD
joepizuro
Magnum v10
Does that come with a shroud?
IrocRam
Phoenix, Az
That's actually not that bad of a price especially if it's being custom built for you. The ones I have been seeing are around that or more and will need some modification to mount it because they aren't vehicle specific.
I figured they had some great functionality about them.
joepizuro
Magnum v10
My a/c doesn't work so I'm going to rip that all out when I have time and ask them if I still need the same stage 5 setup... The stage 4 is a 50 less I think. I just don't want huge shrouds. I want it clean as possible.
rammanriley20
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
I will be ordering the FF dynamics kit.
joepizuro
Magnum v10
Does it come with shroud to mount fans
MagSport
South Carolina
I'm in favor of diy, I like ff dynamics but I also stay broke so that discourages the bunch of money at one time thing lol. I think it would be pretty simple to fab up a shroud if you wanted one.
BBartow
5.9L Magnum
TCP is the only one that makes shrouds. Wouldn't touch their kit regardless.
rammanriley20
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
Im buying two 14in fans that both push like 3000cfm per fan and ill buy a good controller for em
Gr8bawana
6.7 CTD
No. Just the fasteners you pop through the radiator
I did this once and after a couple of years they wore through the cooling fins of the radiator. I figured it was because I do lots of off-roading and the constant vibration sped the proccess along.
