Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Plenum Gasket: What is it, where is it and what should I do about it? *INFO*
This is a discussion on Plenum Gasket: What is it, where is it and what should I do about it? *INFO* within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Like Tree24Likes
Sponsored By: Moe's Performance
Reply
Old 09-20-2013, 03:01 PM   #1 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default Plenum Gasket: What is it, where is it and what should I do about it? *INFO*
*all credit goes to Merc225hp*
“Plenum Gasket, what is it, where is it and what should I do about it” applies to 3.9, 5.2, 5.9 magnum motors.
When Dodge made the intake for these motors they made it in two pieces, cast aluminum for the top and a stamped steel plate for the bottom, with of course a gasket between the two. Over time this gasket fails for whatever reason (there are many opinions on this as to why it fails this is not a thread to discuss that).
Signs that the gasket has failed/failing, oil consumption goes up, pinging from the motor, possible blue smoke from the tail pipe, a miss in the motor (most times cylinder 8), rough idle, fouled spark plugs, general lack of performance.
Is there a test to see if it’s leaking? Not a real good one: Just opening the TB and looking down in the intake to see if oil is in there is not enough. The PCV system puts oil in the intake no way around that fact so that test is out. The idea of looking for oil pooling inside the intake at the back to me is also not a good test as there are vortexes inside the intake that will pick up the PCV oil and drop it elsewhere inside the intake.
What a leaking Plenum gasket can do to your motor: If left for too long, you will foul spark plugs, foul the O2 sensors, plug the catalytic converter (if the cat plugs and you run it that way you up the chance of cracking the already weak heads).
Can you test to see if it has been fixed before? Yes and no you can use a telescopic magnet put down the TB and see if it has a steel plate or an aftermarket aluminum plate. If it does not stick to the bottom it has been changed to the aluminum plate so you might be okay. If it does stick to the plate just start getting ready to do the job.
*notes from DD94: there was a fella somewhere that attempted this and his magnet was filled up with sludge, so depending on how nasty your intake is, this may or may not work. You may have to Seafoam it before you do this*
Fixes for this, from Dodge and other wise:
Dodge did a couple of TSB’s to try and deal with this issue, one is the routing of the spark plug wires (TSB 18-48-98), next is the Death Flash (TSB 18-34-97). Both of these TSB’s are bogus cover ups for the real problem. And TSB 09-05-00 where the job is done in full.
Aftermarket fixes: There are aluminum replacement plate’s out there, one on eBay and the other is Hughes engines, I believe both are full kits. This is the route many take to solve this problem. The other two options are replacement intakes one is the Mopar M1, two is the Hughes F1, and neither are cheap and both should be used with other supporting mods.
*notes from DD94: the eBay is just an aluminum plate with the plenum bolts, Hughes offers both the pan with bolts, as well as a full kit. Going the eBay route and then sourcing your supporting parts else where has been proven to be cheaper in most cases...the Mopar M1 is also unfortunately no longer in production, making them harder to find and they're climbing in price*
Can I fix this myself?: I have read and helped many a greenhorn do this job, some take longer than others but most can do it in a day. The biggest mistake I see is the use of wrong torque setting for the intake bolts, the torque setting is in inch lbs not foot lbs, so make sure you have a torque wrench that reads in inch lbs. The other obstacle is broken intake bolts, it happens, no doubt about it, and most can be removed with a pair of vise grips, however, some may end up requiring the replacement of the heads.
A good shop should be able to do this work in about 4-6hrs, some shops will know nothing of this problem so expect to hear "what are you talking about?"
All part numbers listed are Mopar parts readily available from your Dodge dealer. The P denotes performance parts, in some cases these parts are cheaper than stock parts, the intake bolts are the exact same as the stock part just cheaper.
53030541 Throttle Body Mounting Gasket
05017208AA Gasket, Intake Manifold Plenum Pan
P4876049 Intake Manifold Gasket Set $33.25
P4876772 Intake Manifold Attaching Bolts $7.75 set.
P5249862 Roller Lifters $117.50
Opt parts
P5007709 Timing chain tensioner part $30.00
P5249267 Double roller chain and sprocket set $58.00
Water pump
Cap
Rotor
Oil psi sending unit
Fel Pro 5.2/5.9 Intake Manifold Gaskets with belly pan gasket MS95392-1
*notes from DD94: You're never going to get a better chance to easily replace the cap and rotor, so do it while you've got the intake off.*
I hope this helps someone.
Big thanks to Merc for taking the time to ponder and write all this up for everyone!
Sponsored Ad
Register to remove this ad.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 09-20-2013, 03:14 PM   #2 (permalink)
Ram Year: truck
Engine: gas
Default
I like the added notes DD thanks for polishing it up for the public.
dodge dude94 and Ram digger like this.
Merc225hp is offline   Reply With Quote
Old 09-20-2013, 03:17 PM   #3 (permalink)
Engine: 5.9 Magnum
Default
Sure, man. I also sent PMs to a couple Mods to get it sticky'd.
Merc225hp likes this.
__________________
Old 09-20-2013, 04:10 PM   #4 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
can't you also test the plenum with a vacuum gauge? i know it would probably have to have a pretty bad leak for it to show vacuum in the crank case with the pcv disconnected but it is worth a try.
i think we might also need some pictures to go with this so that people understand what it is better
elpeejo likes this.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 09-20-2013, 04:30 PM   #5 (permalink)
Engine: 5.9 Magnum
Default
There was a vacuum procedure, but I don't remember what the outcome of it was.
As for pictures, pictures of what?
__________________
Old 09-20-2013, 04:52 PM   #6 (permalink)
Ram Year: truck
Engine: gas
Default
TSB 09-05-00 has the vac test in it as well as the plenum gasket replacement steps.
Here are some pix of the plenum, it's gasket, pcv oil spray pattern on the pan (normal).
The kegg intake.
Bottom of the kegg, the steel plenum plate.
Inside bottom of the steel plenum pan.
Broken plenum gasket. In most case's the gasket will be pushed out from between the two parts.
Bottom of the kegg intake.
Pcv oil spray pattern on the plenum plate, (normal)
dodge dude94 likes this.
Old 09-20-2013, 06:11 PM   #7 (permalink)
Engine: 5.9 Magnum
Default
Good thing you had the pictures sitting around, Merc.
This is gonna be good!
__________________
Old 09-20-2013, 06:20 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
here is a picture of how much the gasket can be pushed out on a rusted steel plenum pan. i pull the intake off a truck at the junkyard that had already been picked apart which is why the pan was so rusty.
__________________
Old 09-20-2013, 06:36 PM   #9 (permalink)
Ram Year: 2001
Engine: 5.2
Default
Thanks for the info. I checked out my 01 yesterday and it had burned 1 1/2 quarts of oil some how. Hasn't ever done that before and no8 spark plug was a royal pia to remove. So maybe I'm developing this issue. Plugs looked fine though they were worn to .45 or .46 from the factory .40. Found a vacuum leak in the form of the pvc hose. When these go is it like a big vacuum leak or is there no change in that respect?
meistermash is offline   Reply With Quote
Old 09-20-2013, 06:39 PM   #10 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i don't think it is like a big vacuum leak but any vacuum leak can hurt how your engine runs. most people do not notice the leaking plenum gasket until it has clogged the cat and you loose a lot of power.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oil pan gasket replacement for '98 5.2 Mr. Baseball Tech Info 0 07-18-2013 08:10 PM
98 5.2 plenum gasket$ rwb77w General Discussion 3 06-24-2013 09:03 PM
plenum gasket or other problem???? gesjr Engine & Performance 5 03-05-2012 10:40 AM
blown head gasket or plenum gasket? bigred318 Engine & Performance 8 02-26-2012 08:32 AM
Plenum Gasket set your opinions? MikesRammin Engine & Performance 9 02-11-2012 10:08 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
