05ram4x4
- Aug 28, 2012
- 597
- 34
- 2002 Ram 2500 4x4 Quad cab
- 5.9 Magnum
I have two issues with my new ram. One is that the dome lamp does not come on. The map lights do, but not the dome lamp. Also, the cargo lights don't work either. I check the plug on the dome lamp with the headlight switch rolled up, and it has no voltage. Any idea?
My second problem is my brake lights. I noticed that sometimes my brake lights take a second to turn off, and sometimes they don't. They WILL if I lift the pedal. Is the switch worn out? Or is it more of a brake system issue, as in the pedal isn't rising enough.
ANY help is appreciated!
