found this, might be related...
SUBJECT:
"Service 4WD" Lamp Illuminated On 4X2 Vehicles
OVERVIEW:
This bulletin involves installing a revised HVAC control assembly.
MODELS:
2001 (AN) Dakota
2001 (DN) Durango
NOTE: THIS BULLETIN APPLIES TO 4X2 VEHICLES BUILT BEFORE
OCTOBER 13, 2000 (MDH 1013XX).
SYMPTOM/CONDITION:
The “Service 4WD” lamp is illuminated even though the truck is not a 4X4 vehicle.
DIAGNOSIS:
Start the engine. Once the instrument cluster bulb check has been completed,
verify that the “Service 4WD” lamp is illuminated. If the “Service 4WD” lamp
is illuminated, perform the Repair Procedure.
08-032-00 REV. A -2-
PARTS REQUIRED:
Qty. Part No. Description
AR (1) 55055904AE Assembly, HVAC Control, Durango With
Rear Heat And A/C
AR (1) 55055907AE Assembly, HVAC Control, Durango Without
Rear Heat And A/C
AR (1) 55055905AF Assembly, HVAC Control, Dakota, With A/C And
Rear Window Defogger
AR (1) 55056408AE Assembly, HVAC Control, Dakota, With A/C,
Without Rear Window Defogger
AR (1) 55055906AF Assembly, HVAC Control, Dakota, Without A/C,
With Rear Window Defogger
AR (1) 55056409AE Assembly, HVAC Control, Dakota, Without A/C,
