Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > General Discussions
General Discussions
2014 RAM 2500 CB Installation complete
This is a discussion on 2014 RAM 2500 CB Installation complete within the General Discussions forums, part of the Dodge Ram Cummins Diesel Forum category!
Originally Posted by jadocs For what you want to do, a good basic radio like the Cobra 25 and a ...
Like Tree8Likes
Reply
Old 04-04-2016, 04:58 PM   #31 (permalink)
Jmhm17's Avatar
Ram Year: 2014
Engine: 5.7L HEMI
Default
Originally Posted by jadocs View Post
For what you want to do, a good basic radio like the Cobra 25 and a Wilson 1000 mag mount antenna (see my first post in this thread) will be just fine. No amp needed. You will still need to tune the antenna (as you would on any new setup).
Thanks for replying!
Any other recommendations on antennas? Im not really a fan of the whip style antennas. I have a toolbox I could mount something to, what about a firestik?
Sponsored Ad
Register to remove this ad.
__________________
2014 "Black Edition" 1500 Express CC 4x4
Tuned by Greene Racing
Jmhm17 is offline   Reply With Quote
Old 04-04-2016, 05:48 PM   #32 (permalink)
jadocs's Avatar
Ram Year: 2014
Engine: 6.7
Default
You could do that but you will get much better performance with the antenna on the roof. If you don't mount on the roof...the rule of thumb is to have 2/3 of the antenna above your roofline.
__________________
Using Tapatalk
jadocs is offline   Reply With Quote
Old 04-05-2016, 02:25 PM   #33 (permalink)
Jmhm17's Avatar
Ram Year: 2014
Engine: 5.7L HEMI
Default
Good info. Hmm.. that leaves out the bad ass look of a firestik then.. I just think roof mounts are ugly (no offence).
Also, what about the Cobra 29? its a little cheaper than the 25..
__________________
Old 04-05-2016, 11:47 PM   #34 (permalink)
jadocs's Avatar
Ram Year: 2014
Engine: 6.7
Default
Cobra 29 would work just fine. You can still mount a firestick back there, but there will be trade off in performance. The higher you can get the antenna the better.
Jmhm17 likes this.
__________________
Using Tapatalk
Old 05-19-2017, 02:26 AM   #35 (permalink)
Limeybastard's Avatar
Ram Year: 2015
Engine: Hemi 5.7
Default
Read this post with great interest. Funnily enough found it via Google search even though i post in the gen 4 1500 forums often. Wonder if the coax around the back window then through the back sewt grommet into cab will work on a 1500 QC. I've got my cb and mag mount arriving shortly.
Sent from my SM-T819Y using Tapatalk
Limeybastard is offline   Reply With Quote
Old 05-19-2017, 10:27 AM   #36 (permalink)
AFMoulton's Avatar
Ram Year: 2016
Engine: 5.7 Hemi
Default
Finished pics. Lowering the headliner is not a quick job if you have never done it before. I took my time and it was totally worth it. After lowering the headliner it became clear that there was only one small area between the roof supports to mount the antenna. I was using a mount that had a large surface area to further ensure the roof wouldn't buckle with the weight of the antenna at highway speeds. You've heard the saying that your radio is only as good as your antenna and coax? Well it's true, I'll be damned if my radio isn't louder and clearer.
Antenna Mount: Breedlove SO-239 (#179).
Antenna: Sirio 5000 Performer.
Coax: Times Microwave LMR-240 with heavy duty 3/16" ring lugs.
I haven't even tuned the antenna yet and my SWR is.
Channel 1: basically a flat 1, maybe a hair over.
Channel 20: 1.15
Channel 40: 1.3
Do you have any pics of the install??
__________________
2016 1500 QCSB 4X4 5.7 HEMI Granite Crystal
AFMoulton is offline   Reply With Quote
Old 05-19-2017, 11:02 AM   #37 (permalink)
jadocs's Avatar
Ram Year: 2014
Engine: 6.7
Default
Should work fine, I just didn't like the temporary look of a cable being routed on the outside.
Sorry no I don't.
__________________
Using Tapatalk
Old 05-19-2017, 11:12 AM   #38 (permalink)
AFMoulton's Avatar
Ram Year: 2016
Engine: 5.7 Hemi
Default
Sorry no I don't.
No worries. I'm looking to install a 2m/70cm antenna on mine that I can expand to a HF set up later. What size Mount did you get?? Also where at on the roof is this? Under dome light?
__________________
Old 05-19-2017, 11:18 AM   #39 (permalink)
jadocs's Avatar
Ram Year: 2014
Engine: 6.7
Default
I think I got the large puck. You'd have to see what sizes are on the Breedlove website.
My internal lights are to the front and rear no dome light in the middle. If you do have a center dome light you should be able to remove it and do the install without removing the headliner (you will still need to fish the coax using a coat hanger to an A or B pillar though.
__________________
Using Tapatalk
Old 05-26-2017, 01:25 AM   #40 (permalink)
Ram Year: 2015
Engine: Hemi 5.7
Default
Just read this thread a second time . The CB bug has caught up with me after many decades, I had only a few days ago bought a uniden 505 and tram 705 center mount, already sent them​ back for a cobra 29lx and wilson 1000 magmount on roof.
The radio is temp connected to the 12v cig socket and I intend to route it to battery directly after I finalize location of CB unit ( does it make that much of a difference real world terms?). What linear amp would work with my setup, don't need anything more than 100W , concerned about overcharging the linear with the CB 4W? Finally, you all just connect all these items directly to battery via inline fuse or some sort of junction box? Im assuming the 100W linear wont work of cig socket even if soldered.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
15 min installation of my Vararam on 2014 RAM 5.7 Sport hog4oc Engine & Performance 14 06-04-2014 06:25 AM
3"-2" 2wd coil leveling kit installation complete ! Ram82808 Lifted 14 01-22-2014 07:09 PM
2012 2500 Fog Light Installation wolfpackfan33 Exterior 5 12-12-2013 07:38 AM
Raybestos Struts, Control Arms & other Complete Assemblies Make Installation Easier! RockAuto RockAuto 0 01-23-2013 03:24 PM
finally!! DVD/In dash nav installation complete hemi1300 Audio & Electronics 11 07-20-2012 02:07 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
