Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > VP44 Pump
VP44 Pump
Catch me if you can (MPG)
This is a discussion on Catch me if you can (MPG) within the VP44 Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
Here you go... Gasoline 116,090 BTU per gallon / 3.919 = 29,622 BTU per dollar Diesel 133,000 BTU per gallon ...
Reply
Old 09-13-2011, 08:05 PM   #21 (permalink)
Mopar1973Man's Avatar
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
Here you go...
Diesel 133,000 BTU per gallon / 4.099 = 32,446 BTU per dollar
Diesel still is a better deal...
As for the rise... RV275 injectors, Edge Comp (5x5), and learning how to drive again...
Sponsored Ad
Register to remove this ad.
__________________
2002 Dodge Ram 2500 (Cummins Diesel) -=- 1996 Dodge Ram 1500 (5.9L Magnum)
Mopar1973Man is offline   Reply With Quote
Old 02-08-2012, 04:09 PM   #22 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
Now with the mods I have put in I am down to 17/21
Still not bad IMO
ramhunter9 is offline   Reply With Quote
Old 02-08-2012, 04:52 PM   #23 (permalink)
Default
Knowing you've got larger tires how are you getting your distance number correct?
Percentage offset or using a GPS?
With weather at about -2*F for starting low and +22*F for a high and travel all the way to Ontario, OR get some stuff and head home. With my list of mods and running my 265/75 R16's I pulled... Cmg is my round trip... Tmg was from Ontario, OR to home...
Still I think I got you with even colder and nasty weather...
__________________
Old 02-08-2012, 05:26 PM   #24 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
I want to get one of those gauges.
would probably pay for it self rather quickly if you (I) could learn to drive from it.
__________________
01 1500 SOLD
02 lexus rx300 (power wagon)
rambob is offline   Reply With Quote
Old 02-08-2012, 09:36 PM   #25 (permalink)
Default
Worth every penny... Yes you'll learn that your driving style, mods, tuning, etc. all have a effect on MPG's. Funnier yet the ScanGauge II is more accurate than hand math because the SGII is calibrated and corrected for both speed / distance and fuel flow with my mods. Where my speedometer is off by 0.5 MPH so the odometer is off by about 20-30 miles per tank.
__________________
Old 02-09-2012, 02:07 AM   #26 (permalink)
Stangshcky12's Avatar
Super Moderator
Ram Year: 2007
Engine: 5.9 Cummins
Default
Originally Posted by Mopar1973Man View Post
Here you go...
This caught my attention so I looked into a little bit more. Pressure and temperatures a big variables on both fluids. I double checked the NIST values with the AFDC values, gasoline Is 116,090 btu and diesel is 128,450 btu
The current national average of gasoline is $3.483 so 33,330.4622 btu/dollar
Average of diesel is $3.888 a gallon so 33,037.5514 btu/gal
Unfortunatley the government will always tax diesel fuel so it's price per btu is similar/ less efficient then gasoline
__________________
RamForum.com Moderator
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Stangshcky12 is offline   Reply With Quote
Old 02-09-2012, 11:07 AM   #27 (permalink)
Default
Careful with the diesel BTU value it varies in repect to cetane level...
Using ASTM testing scale for my local summer and winter fuels... Lower the cetane the more BTU's.
__________________
Old 02-09-2012, 11:21 AM   #28 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
if your odometer is off due to larger tires, the hand figures off in what direction?
__________________
01 1500 SOLD
Old 02-09-2012, 03:19 PM   #29 (permalink)
Super Moderator
Ram Year: 2007
Engine: 5.9 Cummins
Default
Maybe with your additives, in that case you have to consider * API gravity, distillation range, sulfur content, stability and flash point to determine BTU content since cetane isn't a measure of fuel quality.
ASTM is not the standard for energy properties NIST is. ASTM did set the standard cetane level at 40 in north America (which is the minimum level recommended by almost all diesel engine manf.) using different cetane levels then the manufacturers doesnt always result in better efficiency. Any graphs I've ever seen no. 2 diesels performance and efficiency both plateau at 55.
Hopefully this works, this is from the dept of energy and matches NIST
http://www.afdc.energy.gov/afdc/progs/fuel_compare.php
Do you have a link for that graph or the information. I'd like to look into it more
__________________
Old 02-09-2012, 03:49 PM   #30 (permalink)
Rogan68's Avatar
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Default
Percentage offset or using a GPS?.
Before I got the Edge Juice w/Attitude, I noticed that my larger tires vs speedo wasn't linear.. sub 30-35mph, the speedo was on the money with the gps. as I went faster, the speedo started to lag.
__________________
'97 ECLB DRW 5.9L Cummins - #0, BHAF, 4" Diamond Eye TBE - Built 47RE
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
Rogan68 is offline   Reply With Quote
Reply
Bookmarks
Tags
economy, mpg
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oil Catch Can Results myoung84 Engine & Performance 49 08-02-2013 06:15 PM
Catch Can for 2004 5.7 Requiem478 Engine & Performance 4 08-06-2011 02:01 PM
Cant catch a break badfish888 General Discussions 16 11-20-2010 10:45 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
