Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > 5.9 Common Rail
5.9 Common Rail
What caused this damage
This is a discussion on What caused this damage within the 5.9 Common Rail forums, part of the Dodge Ram Cummins Diesel Forum category!
Would a weak cylinder that may consume oil plug an injector with carbon? Sent by me...
Like Tree10Likes
Reply
Old 03-04-2016, 11:22 PM   #21 (permalink)
Ram Year: 2005
Engine: 5.9L HO Cummins
Default
Sent by me
Sponsored Ad
Register to remove this ad.
dmuney is offline   Reply With Quote
Old 03-26-2016, 01:22 AM   #22 (permalink)
Ram Year: 2005
Default
Originally Posted by sbarron View Post
I was referring to some of the scorching around the shoulder and across the rim.
Shoulder ?
Old 03-26-2016, 01:25 AM   #23 (permalink)
Ram Year: 2005
Default
Originally Posted by R/T_Fire View Post
Typically the marks in that pattern are due to a bad injector. and you probably got fuel running down the skirt and burning causing rings and such to get blown out and melting.... prob started small. Take a look at the injectors and or replace them. If you are running a tuner there is alot you need to support that extra fueling.
Not knowing all the details of your build or if its stock its hard to say exactly the cause but I would not just put it back together without looking at the injectors... and I always suggest if you change one change them all. its alot of money but just one of those things. also look at the wiring/valve cover gasket for damage. they are known to fail causing injector issues which can result in this...
Also do you have a EGT gauge. and I have a master manual to the 06-07 years on CD if you are interested in it I can email you. just PM me with your contact info.
My truck is stock I think I have egt and boost guage no tuner no injector tips truck appears stock but I only purchased it 3 months ago with 123000 miles
Old 03-26-2016, 10:44 PM   #24 (permalink)
R/T_Fire's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
All of that damage can still happen stock. Dirty fuel or fowled injectors will discuss it. Let me fire up the old computer and pull the manual off it and I'll email it to you...
dmuney likes this.
__________________
2011 R/T - Motor: Diablo T-1000 w/ hemifever, Vararam intake - Susp: Beltech 3/5 drop, hellwig swabars front/rear with adjustable links, full Spohn adjustable rear components. stock r/t wheels and rubber
14.62 1/4 baseline low 12's current goal
R/T_Fire is offline   Reply With Quote
Old 03-26-2016, 11:12 PM   #25 (permalink)
Ram Year: 2005
Default What caused this damage
Thank you so much. Another question but I think I know the answer so after I did the bandaid I put a new injector in #1 after about 1500 miles I had to replace #1 again. And my dumb luck it seems it's time for another injector but I haven't looked at it yet I gonna take a shot in the dark and say it's #1 again. Could low compression damage a injector or ( my stupid luck ) does it need a transfer tube except the original transfer tube is in the trash so that couldn't be it or because factory lift pump and filter are still messing things up. Getting ready to buy a FASS just haven't ordered it yet
And thank you for helping me out with the Manuel I'm sure it will be a huge help
Old 03-26-2016, 11:17 PM   #26 (permalink)
Ram Year: 2005
Default
Can someone with a straight pipe on their Common rail take a video of there truck driving with the windows down at WOT I am only after the sound of the exhaust don't worry about what shows on the screen. And maybe a video with it idling also. Thanks everybody for all the help
05 2500 4dr shortbed 4" lift on 35's, 4" straight pipe, Afe intake
Old 03-26-2016, 11:33 PM   #27 (permalink)
R/T_Fire's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
The manual is a huge help and education into the systems on the cummins.
I'm not 100% sure on a poor cylinder would burn up an injector. It would give poor combustion and should puke out black smoke. You may have an issue with the injector harness may have a nick in the wire poor connection somewhere causin the solenoid to fail. There is a test with a ohm meter to detect if all are working right and it's a ecm issue.
I pulled my hair out with injector issues before I figured out the issue. Went through 2 harnesses and 2 sets of injectors and 3 extra. Turned out it was the fowled fuel system causing the injectors to fail. Probably not the same issue your having but sounds similar
Once I get in from working in the shop, I'll look for the manual and send it over
dmuney likes this.
__________________
Old 03-28-2016, 02:50 PM   #28 (permalink)
Ram Year: 2005
Default
I thought maybe fuel system as well buying a Fass 150 titanium today and getting new fuel transfer tubes might as well get the fuel system taken care of and new injectors before I rebuild the motor.
Old 04-29-2016, 03:37 PM   #29 (permalink)
Ram Year: 2007
Engine: 5.9 cummins
Default CD manual
I just purchased an 07 3500 would love a copy of manual if you would my email is demartino2001@gmail.com thank you
Broncoboy is offline   Reply With Quote
Old 04-29-2016, 03:44 PM   #30 (permalink)
Ram Year: 2007
Engine: 5.9 cummins
Default
Could I possibly get a copy of that manual I just purchased an 07 3500 am new to cummins could definitely use the guidance thanks
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Towing mirrors caused check engine light!!!!! zogg Audio & Electronics 11 05-08-2016 11:52 PM
What caused this? soapy Exterior 3 07-13-2014 05:56 PM
tow mirror caused check engine to come on ollie415 Audio & Electronics 2 11-04-2013 11:04 AM
Rattle in door caused by door speaker beavermosh Interior 10 10-11-2013 07:50 PM
Power wire caused a code I think w8tnonu22 Engine & Performance 2 06-10-2012 10:04 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
