At least the door is there, I'm not sure if the filter itself is installed. It began with later 2016 production.Do the 17's already have this done form the factory??
Did this mod today. PITA. Could not get the door to snap in place on the left side for nothing. No matter how hard I pushed or bent the tab inward. Finally said the hell with it and duck taped it
Haha I did the same thing and it lasted 12 hours before my OCD took over. I could not figure out why it would not snap on there. But if you take a smallish screw driver or something similar and stick it back next to the left tab, after you have the right tab snapped on, you can push the left tab onto the post and it will snap on there. Think the opposite of prying it off. I was angry with my self for how easy that was and not figuring it out in the first place.
My 2017 has the door and filter installed...
Can you link to that intake kit for the hood?It's about time RAM finally stepped up to the plate....could never understand why everything was there but couldn't add a $5 part so the cab wouldn't be a dust pit.... Also Genos Garage sells a CAB filter kit that bolts on under wipers and hood and covers the vents where all in coming air enters cab. I have purchased a few years ago and buy replaceable filters and change them yearly...it really helps along with the blower motor filter. My cab stays nice and clean and low dust on dash. Really helps with pollen too! Highly recommend them....they were designed for semi trucks.
Google genos garage.Can you link to that intake kit for the hood?
Can you post a picture of what it looks like with the hood closed?It's about time RAM finally stepped up to the plate....could never understand why everything was there but couldn't add a $5 part so the cab wouldn't be a dust pit.... Also Genos Garage sells a CAB filter kit that bolts on under wipers and hood and covers the vents where all in coming air enters cab. I have purchased a few years ago and buy replaceable filters and change them yearly...it really helps along with the blower motor filter. My cab stays nice and clean and low dust on dash. Really helps with pollen too! Highly recommend them....they were designed for semi trucks.
Do you know if it's possible to order the geno's garage kit, in Canada ?
I was ready to order a kit and a replacement filter kit for 70$ and then saw a 75 $ shipping quote.
So in CAD it's about 200$ .that's crazy
E Bay that is where I got mine for my HHR, And if I remember the CAF is from a Avenger, But do not know the numberAnyone have the part number for tge cheapest filter? That's what i used last time and was happy. I'm thinking it cost me about 8 dollars
Sent from my SM-T819Y using Tapatalk
These specs sound about right? I specifically want a non carbon one.E Bay that is where I got mine for my HHR, And if I remember the CAF is from a Avenger, But do not know the number
go to your chrysler dealer get the dodge avenger cabin door and hit your local parts store and get the filter it will be cheaper than $70 dollars canadianDo you know if it's possible to order the geno's garage kit, in Canada ?
