This is a picture of the back and the front of the female housing that it plugs into of that helps any.
Those are good pictures Rick. Do you have those 2 parts in hand or are they someone else pictures?
Anyway here is some info I dug up/put together so far (Feel free to quote/add to your OP):
All Yazaki Catalog PDF's can be downloaded from this link:
YAZAKI Connectors Catalog
There is a
difference between the YESC Hybrid Connector line and the 'Standard' Hybrid Connectors. The heated seat connector PN's you are looking for are from the 'Standard' Hybrid Connector Catalog:
Yazaki Std Hybrid Housings:
- PN:
7282-1248
24 Pole
Male (Housing & pins); (20) 2.3mm & (4) 4.8mm terminals
Nexus Electronics:
7282-1248 (Male Housing/pins) _ qty: 200 pcs/stock, $1.38 ea
- PN:
7283-1248
24 Pole
Female (Housing & pins); (20) 2.3mm & (4) 4.8mm terminals
Nexus Electronics:
7283-1248 (Female Housing/Pins) qty: 296 pcs/stock, $1.08 ea
or
7283-1248-50 (ORANGE Female Housing/Pins) qty: 200 pcs/stock, $1.39 ea
EDIT 2 (from next post):
If I am reading this CAD drawing correctly it may be possible to locate the same part in a different color based on the "dash number at the end", i.e. ...
-10: Dark Gray
-30: Black
-40: Lt Gray
-50: Orange
-60: Green
-80: Brown
-90: Blue
Terminal Info Converted to Approx AWG size:
2.3MM Yazaki MALE Terminals (-08 = Au/gold plated):
- 7114-4020 or 7114-4052-08 __ (22-20 awg)
- 7114-4021 or 7114-4053-08 __ (18-16 awg)
- 7114-4022 ________________ (___ awg)
2.3MM Yazaki FEMALE Terminals (-08 = Au/gold plated):
- 7116-4020 or 7116-4052-08 __ (22-20 awg)
- 7116-4021 or 7116-4053-08 __ (18-16 awg)
- 7116-4022 ________________ (___ awg)
4.8MM Yazaki MALE Terminals:
- 7114-4030 ________________ (22-20 awg)
- 7114-4031 ________________ (18-16 awg)
- 7114-4032 ________________ (___ awg)
4.8MM Yazaki FEMALE Terminals:
