Please help me locate this gasket
regcabsplz
Elyria Ohio
5.9 360 V8
Hello. I am working on replacing a few leaky gaskets in my 5.9. so I was watching a tutorial video on the timing chain gasket in particular and this guy has a rubber gasket instead of a paper one. after my fel-pro gasket set arrived mine was paper as well, so I checked the common auto part stores, amazon, rock-auto, summit racing, and no one seems to have it in rubber.
You can see his gasket in this video at 19:35
after getting this far I would like to use a rubber gasket instead of the usual paper one since I know they’re failure prone.
I don’t mind paying extra for something that lasts so if anyone knows where I can get one I’d really appreciate it
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
It is not an easy find several part numbers show up but nothing identical to what is in the video.
TCS45790
TCS45996
53020284
T27787
this is the only single gasket listed without other engine gaskets but it only seems to be coated not a true composite gasket
MAHLE Original T27787 Engine Timing Cover Gasket
https://a.co/d/eIp5g94
54083300
Is listed as a conversion kit but lists the TC gasket and is made by Ajusa which is a reliable aftermarket manufacturer of quality engine gaskets.
If I really wanted a decent gasket I would buy a 1/16 sheet of buna or nitrile on ebay and use a paper gasket for a template and cut it myself.
I could not find viton sheet the correct dimensions for under $50 US
Mister Luck
WEST COAST
5.7 V8
Felpro PermaDry TCS 45952
Timing cover set
FEL-PRO TCS 45952 Timing Cover Gasket Set
https://a.co/d/0ncVU6l
The option is Blue Stripe
OR
PermaDry sometimes referred to as PermaDry Plus
In conjunction with the terminology :
LEM (Liquid Elastomer Molded) technology and
“Leak Repair”
JustinRam1500
