CuylerTech
- Nov 30, 2013
- 3,633
- 961
- NH
- 2015 Big Horn Mega Cab 4x4
- 6.7L
Hey Guys, We (The Harness Connection) are in the final stages of designing and prototyping our Backup Camera harness, Similar to Jeep Guys (RIP) and we just wanted the wonderful people of ramforums opinion. There are a couple ways we could design the harnesses, first way would be similar to jeepguys and if it was factory installed, using the big chassis connector behind the driver wheel well, or more along the lines of the mopar add on kit that runs into the engine bay and then inside the cab.
Factory way would run into the Chassis connector, then you pick it up at the white connector inside the cab and run to the radio. Cleaner install but price will be more because the pins and covers needed for the chassis connector are $$$ even in the bulk we would buy. Estimated Price Point $150 including shipping
Aftermarket/Add on way would basically consist of running the cables from the fuse box along the frame to the tailgate and then run from the fusebox through either the clutch plate or the wire loom boot and then running to the radio all in one harness. Pins are on the cheaper side so price point would be more around $100 including shipping.
Opinions from you guys? Also any harness ideas that arnt already out there that you would like to see? We love hearing your ideas! Thanks guys!
