Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info > 3rd Gen DIY
Sponsored Ads
Register to remove these ads.
3rd Gen DIY
DIY: Tranny Line Pressure Booster
This is a discussion on DIY: Tranny Line Pressure Booster within the 3rd Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! This is a DIY on how to make/wire in a tranny line pressure ...
Reply
Old 06-28-2010, 05:16 PM   #1 (permalink)
OlDirtyJohn's Avatar
Ram Year: 2004 Quad Cab 2500 *Sold*
Engine: Hemi 5.7
Send a message via AIM to OlDirtyJohn
Default DIY: Tranny Line Pressure Booster
This is a DIY on how to make/wire in a tranny line pressure booster. This is very similar to a power wire, and will increase the line pressure in your tranny giving you slightly firmer shifts. In my case with the Sharadon Stage II tranny/VB, it turned my crazy firm shifts into neck jerking shifts. I like it. I like it a lot. There are a number of different ways you can do this, and there is even a pre-made one sold online ($40+shipping).
Parts used:
5-Pack 2.2k Ohm resistors - $0.99
2x Electrical connectors - $3.98
a foot or so of 16-20awg wire
Heat Shrink tubing - $3.99
Tools used:
Wire stripper/crimper
Soldering Iron/solder
Heat gun
Knife
Step One:
Cut two 6" lengths of wire. Strip the ends/tin them. (note, soldering the connections is optional, but highly advised). crimp/solder on the male prongs onto one end of each wire. On the other end of the wires, crimp/solder on the female receptacles and the 2.2k ohm resistor bridging the two wires together. your end result should look like this:
Step Two:
Insert female receptacles into female connector.
Step Three:
Cut heat shrink tubing to length. Slide over wires and connector. Insert male prongs into male connector.
Step Four:
Use heat gun to shrink the tubing. this is what we will be wiring into the line pressure sensor on the tranny.
Step Five:
Locate and unplug the line pressure sensor. It is located on the rear passenger side of the tranny.
Step Six:
Locate the two wires on the sensor you will be working with. The sensor uses 3 wires, the two that are one on top of the other towards the front of the vehicle are the ones you want. wires 1 and 3 in the following pic.
Once you have the correct wires, cut them a few inches back from the sensor, and crimp/solder on the male/female prongs.
Step Seven:
Slide heat shrink tubing over the wires, and plug them into the male/female connectors. use heat gun to shrink the tubing.
thats it! you are all done. now you can plug the resistor connector we made earlier into your new connectors on the sensor. or if you want to take it out, just plug the 2 connectors into each other, and you are back to stock.
and here it is, plugged back into the tranny with the resistor in place.
OlDirtyJohn is offline   Reply With Quote
Old 08-06-2011, 10:50 PM   #2 (permalink)
sullivan's Avatar
Ram Year: 2006
Engine: 5.7 Hemi
Default
I know this is an old thread, but lets bring this alive. Its come to my attention that this little mod is pretty beneficial.
This is one of my little projects for tomorrow.
__________________
Interior:LED Interior, Pioneer AVH4200, Complete Kicker Sound System 1600 Watts|Exterior: Halo Projectors w/ 5k HID, 5k HID Fogs, LED Tails, LED 3rd Brake Light, Debadged, Spray Liner, Cooper Zeon LTZ, Black Billet Lower Grill|Performace: 3.5" Cold Air Intake, Superchips, Magnaflow 22" Exhaust, Transmission Pressure Booster|Suspension: Bilstein Shocks, HellWig Anti-Sway Bar
sullivan is offline   Reply With Quote
Old 08-06-2011, 10:58 PM   #3 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
i like the idea, i was always told, its better to have a quick/firm shift instead of the stock smooth shift. heard it a lot easier on the transmission.
__________________
night vision HID kit, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, vararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels. raceland 3" cutout, SC 3865 tuned, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers.
05singlecabHEMI is offline   Reply With Quote
Old 08-06-2011, 11:22 PM   #4 (permalink)
joetama's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
Which transmission is that a 45RFE?
__________________
2011 Big Horn || 5.7 HEMI || AirRaid CAI || Borla Exhaust || BakFlip || BedRug
joetama is online now   Reply With Quote
Old 08-07-2011, 12:02 AM   #5 (permalink)
sullivan's Avatar
Ram Year: 2006
Engine: 5.7 Hemi
Default
It works on the 45RFE as well. Not sure if thats whats pictured though.
__________________
Old 08-07-2011, 12:21 AM   #6 (permalink)
joetama's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
So is it correct to assume that it would work on the 545RFE as well?
__________________
Old 08-07-2011, 12:28 AM   #7 (permalink)
sullivan's Avatar
Ram Year: 2006
Engine: 5.7 Hemi
Default
I see online the plug you can purchase for $45 + shipping goes to both trannys. So assuming that the guide is correct this will work for both.
__________________
Old 08-07-2011, 05:36 PM   #8 (permalink)
Engine: Hemi 5.7
Default
yes it will work on the 545RFE and the 45RFE. pictured is the 545. they are both the same transmissions, just a difference in tuning.
__________________
2000 Honda Inspire (Acura TL) 2.5l v6 auto, right hand drive. tinted, lowered, debadged, basically riced out to the max!
1996 Mitsubishi Delica Space Gear. 4x4 3.0l v6, bull bars front and rear, side steps, full skid plates.
Old 08-07-2011, 05:56 PM   #9 (permalink)
sullivan's Avatar
Ram Year: 2006
Engine: 5.7 Hemi
Default
John, how exactly did you determine was resistance value was needed, slightly curious
__________________
Old 08-07-2011, 10:27 PM   #10 (permalink)
Engine: Hemi 5.7
Default
thats the value transgo said to use. same resistor also comes with their shift kits.
__________________
Reply
Bookmarks
Tags
line pressure, line pressure upgrade, pressure booster, transmission line
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
