Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > 3rd Gen DIY
3rd Gen DIY
timing chain cover
This is a discussion on timing chain cover within the 3rd Gen DIY forums, part of the 3rd Gen : 2002 - 2008 category!
I had to replace my water pump and found a non used section of the water pump corroded. when I ...
Reply
Old 11-26-2016, 02:33 PM   #1 (permalink)
Ram Year: 2006
Engine: 5.7
Default timing chain cover
I had to replace my water pump and found a non used section of the water pump corroded. when I cleaned it out there was a pin hole in the timing cover. it looks like the hole is from corrosion on the water pump side, not from something rubbing on the inside. any thoughts on this? leave it, replace or some jb weld?
I should state that I really do not want to replace unless it is a must.
pump was working fine, the small water tube for the heater corroded is the reason for replacement.
Sponsored Ad
Register to remove this ad.
ezover is offline   Reply With Quote
Old 11-27-2016, 03:00 PM   #2 (permalink)
Core-Lokt's Avatar
Ram Year: 2005 Ram 2500 4X4 ST
Engine: 5.7L
Default
The JB Weld sounds reasonable to me in this case.
__________________
Core-Lokt-The Deadliest Mushroom In The Woods
Core-Lokt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
what gasket for timing chain cover 04 4.7 four4fish Engine & Performance 1 06-24-2016 06:39 AM
Should I be driving with a timing chain cover leak? latlog7 Engine & Performance 12 05-13-2016 05:04 PM
timing chain 14hemiexpress Engine & Performance 20 04-21-2016 10:07 AM
Timing chain cover Mindtheater Engine & Performance 3 09-14-2014 09:35 PM
Timing Chain Help bjbockemehl Engine & Performance 4 07-21-2014 01:24 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
