How Is My Truck Equipped? Dodge Ram Build Sheets
PaPitt
Stephenville TEXAS 76401
5.9L
... THAT GOOD INFOMATION . AS A LOT OF YOU GUYS CAN DO THE PULL UP & PRINY OUT AT YOUR ON PLACE.
.... bUT FOR A 2ND WAY TO GET THIS INFO .
i WORKED AS A SERVICE ADVISOR FOR 10 YEARS . FROM ABOUT 1995 UNTIL 2004+..
So each time I buy a new toy. I CALL UP TO MY LOCAL STEALERSHIP .. I speak o a service advisor & Ask them to print me an Opitions sheet for this VIN Number .
Options sheets are a neat piece to fine out what amp alt you should have.
rear axle ratio. Gallons in your fuel tank.
& also you can find out what recalls are out on your ride .
.. & What kinds a services it has had.
Wha's ben done to it under warranty .
Beemer533
CNY
2014 Big Horn 2500
None of these links worked for me until I realized that I had to put the VIN in all caps...
Pretty cool to see the original build sheet. Confirmed that I have 3.73, limited slip rear end and that my truck originally came with tow hooks and someone decided to remove them:shrug:
horace33
MN
97 dodge 18LARAMIE
I was lucky window sticker was in my passel of papers
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The Build Sheet
Only states exactly how your Ram was built
It does not read what options were available at the time
Mine was 4 to 6 pages long
The window sticker
reads standard options that were available
on the other side of the window sticker, it has a condensed version of what your Ram came with
It is only 1 page
Goodie1990
