TC-W3 2 cycle oil in the gas
monteholic
6.4 hemi
seen this on the power wagon facebook page
they discuss using 1 once of 2 cylce TC-W3 spec oil for every 5 gallons of gas, there's over 50 pages of discussion on it at the LS forum with no negative effects, thinking about trying it on my Saturn Astra before trying it on my PW
here's the link to it at the LS forum
Been testing Oil
R.L.K.
Bristol , Tn.
Yep , they use it as a UCL Upper Cylinder Lubricant.
Lots of guys do this on their 5.7L Ram's as a cleaner and metered alternative for UCL especially when running an OCC .
I suggest you posting this in the synthetic oil thread here.
https://r.tapatalk.com/shareLink?ur...&share_tid=27664&share_fid=17770&share_type=t
Synthetic Oil
Just go to the last post and post up the same thing you did above .
Hope this helps generate more discussion Sir .
monteholic
monteholic
6.4 hemi
Synthetic Oil
that thread is about crankcase oil
I'm talking about using 2 stroke oil as a gasoline additive
R.L.K.
Bristol , Tn.
That thread has a thousand different subjects Sir , your TCW & many other UCL Have been discussed there extensively .
If you want discussion on UCL post it there imo .
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
640:1 ratio
I use Pennzoil Marine TC-W3!
Pennzoil 550022771 XLF Marine Synthetic Blend Engine Oil (TC-W3) - 1 Gallon https://www.amazon.com/dp/B00C43BOTM/ref=cm_sw_r_cp_api_SkfByb80VD3NJ
Sarge & I had a few conversations. Before losing touch with him.
I will admit the only true benefit that I have actually witnessed/hearing is quieter injectors. The UCL part --->you just have to have faith/believe it is doing just that! One thing to remember the TC-W3 is totally Ashless so no deposits will be formed as well as Full of Detergents.
PM me anymore concerns or questions. I'm sure this post will be deleted here.
crazy jerry
WY
I have dirtbikes and put the extra premix gas in my '96 Dakota so it isn't sitting around the garage. only thing you have to watch is don't put to much oil or its likely to kick on the check engine light and maybe throw some goofy codes
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Jerry: @ 640:1 a CEL will never appear nor will your Kitty's show any ill effects.
Remember in normal circumstances this oil is used at either 32:1 / 40:1 / 50:1 we are talking about 640:1. Most owners have a very hard time grasping that for some reason.
Goodie1990
