Colby_Jackson
- May 24, 2015
- 36
- 9
- 2014
- Hemi 5.7L V8
What's the adapter look like? My oem one is the larger square style not this flat kind
Sent from my LG-H811 using Tapatalk
It's the right year.. 09-14 and the assembly fits directly in its just the wire harness that's different.. If there's an adapter harness I'll buy it. Every other aftermarket tail light says it "doesn't fit" the oem tail lights, now I know why.I would check to make sure you got the proper year.
Is there anyway to special order the inverse? Or hell maybe a way to make one?I don't know of a way to get those working.........
We make the adapters to go from that style to the OEM ones......not the inverse.
Those look like the Spyder LED Tails like I have , if so it's plug n play no harness required ....What do I need to make this connect to the oem wiring on my 14 ram 1500 express blackout package.. I have the sport tail lights and got these.
View attachment 61310View attachment 61311
After looking closer mine are led sport.. But my reverse light is actually a bulb.Those look like the Spyder LED Tails like I have , if so it's plug n play no harness required ....
I removed my OEM non LED tail light assy , plugged the factory harness from the bulb to the new Spyder tail assy and then took the back up light bulb out of my OEM tail assy and plugged it up to the new Spyder tail assy .
That LED tail you have there LOOKS like the LED Spyder LED tail for a non LED equipped truck .
Did you have LED tails already ?
If you did not have LED already unplug the top bulb and plug the Spyder Tails plug right to the bulb plug ...
Hope this helps !
Those look pretty sweet, by the pictures tho they don't look that smokedYou can look at these lights, These will fit models with OEM LED Tail Lights
Smoke Fits 13 16 RAM 1500 2500 3500 Lumileds LED Perform Tail Lights Brake Lamps | eBay
