05 engine swap
Max1329
5.7 Magnum hemi
yes I know I’m goin to be attacked for asking and yes I searched but here we go
I’m 99% sure I just dropped a lifter on my 05 hemi and I’m just tired of this motor it was rebuilt 13k a go and is already having problems any input would be much appreciated
ST-8
Buy another motor if you don’t want to **** with what you got now.
HemiLonestar
MD
Only reason you'd "get attacked" is if your unspoken/untyped question was how to do a non-Mopar engine swap lol....but it would help if you ACTUALLY asked the question
Max1329
Max1329
5.7 Magnum hemi
Sorry about that completely forgot it’s been a long day, I’d love a 6.1 swap but they’re pretty rare down in fl, however I’d be open to suggestions or opinions
HemiLonestar
MD
Well, for starters you have a 2005, so you're covered so far as tunability. How deep 1) do you wanna get into it & 2) are your pockets lol? You could stroke your stock engine, you could drop in a 6.1, you could stroke a 6.1, skies the limit depending on how deep into it you wanna/can get.
Max1329
Max1329
5.7 Magnum hemi
It is just the daily so just fun steer machine is the goal and not a crazy amount right now preferably
HemiLonestar
MD
Ok, so on the cheap. P&P + BV your stock heads (or get a set done) and cam it, get it tuned (since you'd have to custom tune it anyway you can get that EGR turned off in the tune). Headers and Y pipe if you don't already have them. Voilà!
HemiLonestar
MD
With that you'd probably still be ok with the RFE not crapping out on you
Max1329
Max1329
5.7 Magnum hemi
Yup that seemed to be the best rout, already got headers and x pipe, how likely am I to need a complete rebuild because of this?
HemiLonestar
MD
Complete rebuild of what?
HemiLonestar
MD
Of the valve dropping
Ah, you said lifter in the first post, hence my confusion. Depending on how much carnage it caused, best case scenario scored cylinder wall you can get it bored and rebuilt. Worst case scenario it REALLY gouged a cylinder wall and it isn't worth saving the block. Might be better off getting a long block or even a short block and you can put the heads and cam in you want and just drop it in. f8baa073a9d868d7d0cc78ad89bdfcc3.jpg
Max1329
Max1329
5.7 Magnum hemi
Yea sorry I’m not 100% what it is I’m doin A compression test tomorrow to see
chrisp2493
Always Modding
Warren, OH
392 Hemi
You gotta get an idea of what damage is actually done first. Most damage is repairable, depending on your skill level, local machine shop's ability and your pocket book. Just telling us you want it cheap doesn't help. To some 2 grand is not worth it, others can drop 6 grand and not think anything of it.
ST-8
This sums it up perfectly
Max1329
Max1329
5.7 Magnum hemi
Sorry forgot to update thread I did drop a valve but no damage to piston or block luckily so had her up and running by the end of the day
