Kgames
I'm looking at putting a leveling kit on my 2018 ram2500 6.4. I found a 2.5 rough country with shocks and was thinking of getting it. And I'm looking at 20x9 fuel assault for it. My question is with 2.5 in the front should I get a 1" spacer in the back also or will it sit level without it. I'm thinking about putting 35x12.5 on it also but not 100% sure
Ram Wagon
SW Washington
check out this site, call these guys they will give you all the info you need whether you buy their stuff or not.
https://www.thurenfabrication.com/products/dodge-ram/2014-18-2500-2013-18-3500.html
Brian2081
Weatland Michigan
Hey Kramer, click on my pic above, 16 2500, RC 2.5 spacer with the shock lower extensions. The ride is very comfy, but you will need to get the adjustable panhard bar so you can recenter the axle. When you do the level it will pull the axle about an inch to the left (drivers side) and your steering wheel will be slightly turned to the left, but that will straighten back out when you adjust the panhard bar.
Also Thuren recommends rotating the lower bolts on the trailing arms one notch to the rear to help bring caster back towards a normal setting.
This is the setup on my truck which is running 35 12.5 18 Falken Wildpeaks M/T on stock rims. At a hard full lock the tires just barely rub the trailing arms. And I mean just barely.
Ftank
