1988 D100 V6 3.9 codes 26 & 33 ?
Discussion in 'Engine & Performance' started by MiMod, Apr 22, 2017.
Sponsored By: Moe's Performance
  1. MiMod
    MiMod Junior Member
    Apr 22, 2017
    Ram Year:
    1988
    Engine:
    V6
    Not sure whats going on with my truck. Stumbles terrible if I go to restart it after warmed up either right away or 1 mile down the road. Can barely limp it home... Ran the codes on the info panel & coming up with code 26 & 33..
    33 is I think a AC Clutch relay circuit & the truck never had AC so I don't know if that's important..... Can't seem to find what a code 26 is... Appreciate any impute I can get on whats going on. Thanks
  2. crazzywolfie
    crazzywolfie Senior Member
    14,041
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    do you have a multimeter and know how to use it? this might be what the issue is
    1980s Chrysler, Plymouth, and Dodge computer fault codes
  3. MiMod
    MiMod Junior Member
    Apr 22, 2017
    Ram Year:
    1988
    Engine:
    V6
    Well thanks for the info.... What I have is an 88 D100 with the v6 in it. It has a factory Holley, ( I assume TBI).... My next question is where are these connections located that you suggested cleaning and OHM testing ? I have a bank of connections on top of the passenger rear side Valve cover. I also have some wires in the TBI on the Top side.
    Its weird, yesterday it was stumbling everytime I started it & today it started and sounded fine.... But its still throwing a code 26 today ....
  4. crazzywolfie
    14,041
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i think you might have to take the top off above the injectors to get to where you need to be to check them with a multimeter.
    did you erase the code? if not it is likely the same code stuck in the system. i think codes generally stay in the computer for 50 key cycles or something like that. i think you can reset the computer by disconnecting the battery and trying to start the truck. should clear the codes.
  5. MiMod
    MiMod Junior Member
    Apr 22, 2017
    Ram Year:
    1988
    Engine:
    V6
    Ok Thank you again ! I have the air cleaner off and can see 2 possible injectors looking down the barrel of the TPI... They appear to have Black Caps over them. Is this where your talking ? If so then I guess what your saying is pop those covers off & then ???? Just disconnect, Clean the connections and run the current test......Correct ?
  6. crazzywolfie
    14,041
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    ya you have to pop the top of to get access to things but if it seems like it is running better you could put it off see if the issue has sorted itself out. could also try clearing codes.
  7. MiMod
    MiMod Junior Member
    Apr 22, 2017
    Ram Year:
    1988
    Engine:
    V6
    Ok I'll unhook battery & see if that clears code... I ordered a new o2 sensor & That should be here Tuesday... Thought that might be the problem.... If not then I'll proceed with your idea... I appreciate your help.
  8. crazzywolfie
    14,041
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    Was it a ntk brand o2 sensor? These things prefer a ntk brand o2 sensor
  9. MiMod
    MiMod Junior Member
    Apr 22, 2017
    Ram Year:
    1988
    Engine:
    V6
    YES NTK, I think I picked up on that one from one of your other posts. By the way, unhooked battery & reset computer, now no code 26.... Spooky, It has rained here pretty hard all spring & then been dry and windy for the last few days... Humidity/moisture ?
  10. crazzywolfie
    14,041
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    it is possible. you never really know with old vehicles. could be something simple or just a bad connection.
Share This Page
