1992 d150 fuel pump
Discussion in '1st Gen DIY' started by evanblain, Nov 14, 2015.
  1. evanblain
    evanblain Senior Member
    394
    61
    Nov 5, 2013
    Alberta, Canada
    Ram Year:
    Engine:
    Hey guys I got a new to me d150. I've done a little maintenance but now it's time to replace the fuel pump. Anybody have any tricks to remove the tank fill and vent lines or the quick connect to the pump it's self. Thanks.
  2. crazzywolfie
    crazzywolfie Senior Member
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    does the pump itself still work? if so just leave it alone. the stock ones are just as good if not better than any aftermarket one out there. if it is bad then there is really nothing to dropping the tank on a truck. just unbolt it and drop. you pull the plastic locks off the fuel lines and just twist back and forth off the sending unit.
  3. evanblain
    394
    61
    Nov 5, 2013
    Alberta, Canada
    Ram Year:
    Engine:
    It's this guy that I'm worried about. Then theirs a plastic connector on the hose behind it. I was thinking about busting the little nipples off the old pump then worrying about them after I get the tank out. And for the fill line just try to take it off at the tank?
  4. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    you are best to get the tank onto the ground and then pull them off. from my experience that connector does not look right for these vehicles. should be plastic connector connecting to the sending and i think the line to the frame is also suppose to be some sort of plastic or at least it is usually when stock
  5. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    the stock connector and lock clip should have looked like this
    [​IMG]
  6. evanblain
    394
    61
    Nov 5, 2013
    Alberta, Canada
    Ram Year:
    Engine:
    Yeah it's probably a replacement line. I believe the connector behind it looks like that one.
  7. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i wouldn't worry about it too much. if you drop the tank and can disconnect it at the other end so you can get the tank out it might make the line easier to remove from the sending when working on it while not under the truck especially if that is the type of connector i think it is. i think you will need tools like this to remove that connector if it is the type i think it might be and even then it is a real pain in the ass.
    A/C and Fuel Line Disconnect Tool | Princess Auto
    also if you do damage that connector i don't think it is a big deal i am not 100% sure which one that is but i think they should have replacements and if all else fails you could probably get away with fuel line and hose clamps.
    doorman part numbers
    800-053 http://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=800-053
    800-054 http://www.dormanproducts.com/itemdetail.aspx?ProductID=20636&SEName=800-054
    800-055 http://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=800-055
  8. evanblain
    394
    61
    Nov 5, 2013
    Alberta, Canada
    Ram Year:
    Engine:
    Hey Crazy or any one really. I got the whole pump changed except this fitting. I broke it off the old pump just to speed things up and now I can't get it out to attach the hose to the new pump. I bought one of those tools you linked but the piece inside the fitting isn't perfectly round. Anyone got an idea or should I just rip the hose off the truck and replace it.
  9. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i hate to say it but you may end up needing to replace the fitting. you could try drilling the plastic out but it will still most likely damage the seal.
  10. Sniper X
    Sniper X Senior Member
    49
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    I just did this on my 1991 W150. I decided to NOT drop the tank because right before the pump went south, I filled the damn tank! Soo, I did the truck bed tilt way. Worked out very easy and was a breeze. Those connectors are easy to get off safely if you are careful if you have room. And you have plenty if you tilt the bed. If you want me to walk you thru the tilt bed how too, let me know here and I'll do it happily. But generally, there is a clip in the connector that is or used to be white plastic, it is probably yellowed by now. When you have the bed u-p and out of the way before you do anything else pinch the clip with a tiny slim needle nose plyer and just pull the hose straight off.
    Don't force anything and you'll get it.
    to tilt the bed simple remove the two bolts in the front of the bed, and the two center ones, halfway loosten the back two and then hook up a engine hoist to the fornt of the bed and simply tilt it up outta the way for safety use a couple jackstands under the bed between it and the rails and you'll have all the room you need. Here's a video on a 1996 but it is the same proceedure. Don't worry about the pressure deal he explains because the tbi trucks have low pressure.
    https://www.youtube.com/watch?v=XZSPFxthp0k
Share This Page
