1995 ram 2/4 drop going for a 5/8 or 6/9 drop
johnmarks
7.2l 440
has any body else gone this low and are there any issues you run into im c notching the rear and flippign the axle and using blocks in rear in front gonna be using 3 inch drop coils and 3 inch belltech drop spindles and new lower control arms does anyone have any suggestions or expierience with this low i know what im doing just looking for advice
WhiteExpress
Midland, TX
That's going to be badass!
Do you already have the 440 in there?!
6" drop up front unless you're running 17s and lo-profile tires you'll have to worry about tire fitment. a flip kit will net you about 5" of drop (been there, done that).
Be sure to weld the flip brackets to the axle.
Even at that, with a standard notch you have VERY limited upward travel.
You'll likely need to do a 'bridge' notch as opposed to a C-notch.
And cut out your wheel wells.
6/8 static drop would be badass though! Oh yea, make a new transmission cross member too!
J
johnmarks
7.2l 440
No I'm building the 440 up with the build I have planned I should have around 700 horses and 850+ ft lbs of torque
J
johnmarks
7.2l 440
And does anybody know what 5 speed trans I can run to stand up to the 440 I was figuring on an nv4500
Sent from my HTC6500LVW using Tapatalk
Lawhand
Baton Rouge, LA
we need pics!!!! cant wait to see it finished. with a 6" drop and 17 rims with low pro. your truck will be like 1-2" off the ground at the most haha.
Orca
