2/4 drop bushing upgrade help
Syke001
Want to swap out rear end link bushing for poly need part number or size
Don't know if anybody has found a poly bushing that'll fit the stock locating arms.If you find one post up the part number .Most guys just replace the arms with better ones from somebody like Core
S
Syke001
The end links are not stock there the belltech short ones that come with kit
My bad,your post is a bit misleading,i thought you were referring to the locating arms.Next time specify you're talking about the "swaybar" endlinks,makes it easier for guys to know what you want.Hellwig makes adjustable endlinks with poly bushings,and i'm pretty sure there's a couple other outfits that do to
