2/4 drop wheel and tire sizes with wider wheels.
13RAMSRT
Looking to go wider mostly in the rear. Wanna go 20x12 if possible. And was thinking 325/30 or 325/35. Does anyone know what the widest tire is that can be ran in the rear with a 2/4 drop? I've been doing research on this and couldn't find what I was looking for is the reason I'm asking.. appreciate the help.
You'll be okay if those are 20's.The rear usually has no issues,it's the fronts that give you static if you lower it and go to a wide front tire,they quite often will wear a hole in the front fender liners.
