2001 dodge ram 1500
emoney
5.9 magnum
So I've done just about everything possible and my brake lights and hazard lights wil not work have turn signal just not those have replaces the turn signal switch and the brake swith under the brake pedal all fuse are new all new light bulbs I'm bout ready to burn this truckk!!! Help !!
MADDOG
Out Exploring Arizona
Sounds like a broken wire. Have you electrically tested all the circuits?
E
emoney
5.9 magnum
Yea it's giving me an open current
dapepper9
Iowa/Nebraska Border
5.9L V8
What kind of trailer harness you got? The plug and play harnesses can get moisture and dirt in the connections and corrode the metal. I had the same issue with mine
E
emoney
5.9 magnum
A plug one but the actual one on the truck don't come on nothing bout a trailer
dapepper9
5.9L V8
I realize that. If the harness has a connector under the truck by the taillight that taps into the factory taillight harness, unplug it and run just tailights no trailer harness and see if it works.
E
emoney
5.9 magnum
Ok the only harness I se is at the back of the plug and I disconnect it and they still won't run
NightMares
Boise, ID
Trace the wires. See if something is pinched, split, or loose. Check all connections along the frame rails, and pull everything apart to make sure there's no dirt or corrosion in each one.
