2004 Ram 1500 5.7L Hemi Is Producing Oil Smoke At Idle
Insephet
Tennessee
Hemi 5.7L V8
I bought a used truck from marketplace a while ago and didn't see this problem when I was test driving it, good job me. I have now figured out that it is burning a heavy amount of oil when it is idling. If I sit for a minute at idle and then rev the smoke gets forced out of the exhaust and creates a big white cloud behind me. If I sit there and hold the rev above idle no smoke comes out, and I don't notice any smoke while driving.
Administrator
I
Insephet
Tennessee
Hemi 5.7L V8
And to elaborate:
Oil = piston rings/cylinder walls. Water/coolant = head gasket.
OP, did you have a question or just here to vent?
I wanted to see if anyone had any other ideas on it, I don't know too much about internal engine diagnostics and wanted to see if it could be anything else that is specific to this engine. I've been hearing from a lot of people that it is probably valve guides, as it doesn't constantly blow smoke after the cloud exits the exhaust when revved up.
Also, yes I do know that oil smoke is mostly described as blue, I also smell the oil burning which is why I said that it was oil smoke.
That being said, does anybody recommend a place in the Knoxville area that I can take it in and have work done on it? I do not have the space, nor the tools necessary to do any rebuild or repair at home.
Dodge 1500 4X4
Rochester, NY
There used to be a modulator valve on the transmission that uses engine vacuum if that valve goes bad it can start sucking Trans fluid and hence smoking tail pipe I would do a compression test, dry one first, a wet one next use a pump oil can and squirt a couple of shots in the spark plug hole and see if the compression increases the oil helps the rings seal, that will tell you the condition of the piston rings.
KenR 955
Greater Knoxville TN
Ellis auto in Seymour is highly recommended, as is County line garage.
