2005 overhead console wiring
Johng2005
Nazareth, PA
4.7 Flex
My 2005 overhead console needs new wiring as the passenger side reading light switch button is missing parts. Any idea where I can get either wiring or just the switch button for the light? Thanks
HemiLonestar
MD
Junkyard, any Mopar 2002 to 2008 with similar overhead consoles will have the wiring you need. If that doesn't pan out, ebay is FULL of them, especially cheap used if it doesn't have the module with it.
wade w
canada
any auto wrecker should have what you need . You also do not need the wiring . there is four screws on the back of the temp and compass gauge . remove that and look for a new housing with the lights intact . I just found mine at a wrecker in my city in canada . there were dozens to choose from so you should not have a problem finding one .
David Baker
Kentucky
Just replace the switch. I did the same a couple days ago. Search for dome light switch on Amazon. I used the Dorman switches.
Orca
